Page 11 of 13 FirstFirst ... 78910111213 LastLast
Results 201 to 220 of 241
    #201
    any highly recommended shop in banawe that install this correctly?
    Jan 2008
    #202
    dapat ang grounding wire is nearest to the negative terminal of the battery... kung masyado na mahaba yung wire useless na din yan.. dapat short wires lang..
    tapos maganda may mga jumpers ka sa mga dugtungan ng sasakyan lalo na yung mga luma na kasi mahina na yung mga links sa dugutungan ng body
    #203
    P650 yung bili ko dati one year ago...sa del monte qc, ako na lang ang nag-install, nissan sentra 93, madali lang naman, ayun, lumiwanag yung headlight and overall, nag-improve yung electrical system
    Feb 2005
    #204
    Has anyone installed a grounding kit to an Opel or some other Euro car?
    Any feedbacks?
    Jun 2010
    #205
    mga sir is it ok to install grounding kit for honda civic vti 98? parang grounded kasi yung head unit ko (CDR-KING P680.00 ) tapos parang iba pasok ng kuryente? what do you think mga sirs? tnx po. merry Christmas!
    #206
    Mas maganda nga kung mag install ka ng grounding kit twelve years na rin iyong stock na grounding mo na babad sa init ng makina ang wire at iyong pinagkakapitan nito baka kalawangin na at may umido para maimprove din ang steady na kuryente at stable na idle sa sasakyan mo.
    Jun 2010
    #207
    Quote Originally Posted by speed unlimited View Post
    actually yung idle ko eh may problema na, namamatayan na ako... is it the reason sir speed unlimited?
    if that's the case i should invest na din sa grounding kits.. magkano kaya yun ngayon?
    Feb 2005
    #208
    just got my grounding kit and have it installed.
    got it at Delta Auto Interiors sa Shorthorn in Proj 8. (across Monterey) for 1.2k, including installation
    #209
    Adviseable na po bang mag install ng grounding kit ang mga new car?salamat
    Jan 2003
    #210
    nope. old cars need it cause the grounding points and wires due to age and exposure to heat and elements may have already corroded. it's either you trace the old points clean and install new wires, or go the easier way and tap new ground points.
    Mar 2011
    #211
    makakatulong din ba sa carbureted na engine ang grounding kit? what are the benefits? TIA
    Jul 2010
    #212
    Quote Originally Posted by NeoDyMium View Post
    Pag nagawa properly ang installation ng "grounding Kit" ay parang bago ang battery mo. Syempre, kasunod nito ay gaganda electricals. Gaya ng Starting, lalakas headlamp, di mag dim yun gauge lamp pag nagsignal ka at improve konti sa fuel consumption dahil lumakas high voltage sa spark plug.
    Siguraduhin linisan or lihaiin yun parteng lagyan ng ground wire.
    Feb 2010
    #213
    mga sir, saan ba nakakabili ng 0 (zero) gauge wire? I'm planing to upgrade my wirings but I want to use those thicker wires. I tried looking for one in raon but sadly they only have 4 gauge.
    Apr 2009
    #214
    Nag-tap ako ng ground malapit sa electronic joints nung carburetor ko kanina?
    Wala kasing magawa eh.
    Napansin ko pino kaagad ang idling niyan even on cold start.
    Tapos kanina sa SLEX parang nag-improve torque ko sa low to mid.
    Ewan ko lang kung may epekto ba yung pinag-gagagawa ko kanina?
    May 2011
    #215
    ask ko lang po if grounding kits affect gas consumption..ang pangit ksi mag'idle nung akin eh.nagvvibrate yung mga barya tska yung kambyo kaya gusto ko magpakabit ng grounding kit kaso baka may effect sya sa gas consumption.baka maging mas matakaw sa gas
    Jul 2010
    #216
    Medyo tipid sa gas pag may grounding kit. Tataas uli sa normal ang voltage para sa mga electricals. Gaya ng +12V supply voltage ng Alternator sa Battery ay tataas uli ng +14V at sa Ignition coil or Distributor built-in ignition coil. Syempre tataas lalo yun High Voltage para sa mga spark Plug. So, mas maganda sunog ng gas sa engine.
    Mas effective ang grounding kit para sa mga lumang kotse.
    May 2009
    #217
    As per my case, I balked the idea of installing a grounding kit....
    What I did is to spray WD-40 on all bolts connecting the cables then loosen a quarter turn then retighten....plus wire brushed the dirt, grime, etc accumulated around the bolts.
    It worked a bit (in my case).
    Apr 2011
    #218
    ano ba magandang brand ng grounding kit, syaka san magaling na nagkakabit niyan. qc area, del monte.
    #219
    *snowblind
    Maraming magagandang brand ang grounding kit depende sa budget mo at kung del monte q.c ang location mo malapit ang banawe para mag canvass.
    Jul 2011
    #220
    ups ko lang sana meron magpost uli ng mga pics,,interested din ako para sa pregio ko ;-)
grounding kits
