Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 70
    #41
    got mine installed last month, DIY! connected it to alternator, cylinder head, intake manifold, transmission and car body. medyo matagal ang install kasi ginawa ko e hindi 5 pieces of wire, 2 pieces lang. 1 went to the car body, then the other went to tranny, intake manifold, cylinder head, then alternator. puro pig-tails lang from one wire at malaki yung wire na gamit ko, #4 awg.
    noticed changes:
    1. pag start ko ng engine, taas ng rpm nasa 1200 rpm. siguro dahil nanibago yung ecu. then slowly bumaba siya to 800 rpm at steady na siya dun.
    2. nawala yung slight hunting na napapansin ko dati. dati kasi naglalaro sa 750-900rpm, ngayon steady na siya. magbago lang ang rpm pag nag-kick in ang a/c, tapos balik sa 800 rpm after 2-3 seconds.
    3. lumiwanag ang headlights konti.
    pag-uwi ko next month mag-add ako ng isa pang maliit na wire (#10awg) to the ecu. tinamad kasi akong kalasin yung glove box, e di ba andun sa likod nun ang ecu? saka palitan ko yung negative battery terminals. yun kasing oem isa lang na wire so gumawa ako ng battery terminal dito sa rig, 3 ang terminals. brass ang material para walang rust.
    car is lancer mx nga pala. sorry no pics, wala ako digicam e. malabo naman kuha sa cellphone panget i-post.
    Jan 2003
    #42
    i plan to upgrade my head lamps to 100w. so dapat mag upgrade ng headlight wirings n relays n sockets.
    will these grounding kit conflict the headlamp wirings?
    ano dapat mauna ko pakabit groounding kit o headlamp wiring upgrade?
    thnx
    #43
    nope, no conflict pards. ground wires will in fact complement your headlamp wiring upgrade. since mas malakas ang load, dapat mas maganda din ang ground. yung headlight upgrade mo will increase the capacity of the positive side of the electric circuit, the grounding kit will increase the capacity of the negative circuit.
    #44
    pano kung may maling mangyari sa mga connections na ginawa ko. may masamang effect kaya? wala kasi akong alam sa ganyan. balak ko pa lang subukan.
    salamat!
    #45
    Short circuit... if you're not sure, let someone handle it for you. But don't worry, instructions (like those diagrams posted here) are pretty clear naman.
    #46
    basically naman you will just be adding ground connections so i don't see any possibility of getting things mixed up. wala ka naman tatanggalin na connections, mag-add ka lang ng extra grounding.
    kaya mo yan pards!
    Jan 2003
    #47
    meron kaya grounding kit sa rey's o sa wizards?
    how much kaya?
    di ko kaya DIY e
    #48
    had mine done at the carwash at examiner street..the one nearest to quezon ave. for 900 petot with kabit, ok na. beats the guessing where to put time..at medyo tamad ako sa kabit kabit na ganyan e.hehehe
    i agree, the grounding kit will complement the headlight wiring upgrade.
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
    Jan 2003
    #49
    pwede ba ito sa carb engines?
    #50
    pwede sir. kahit diesel pwede. in case of carburated engines or diesel it's just to improve the elctrical grounding para mas maganda charging ng alternator at fully grounded ang starter motor. plus better grounding for the ignition system for the gas engine. ang connections will be sa alternator, engine block, car body and battery negative terminal lang, wala na sa intake manifold.
    sa efi and auto tranny it gives better performance for the ecu.
    Nov 2003
    #51
    Quote Originally Posted by benchph1
    this is the DIY of the month sa HCP. already did it on my honda city and our kia carnival :D
    bench, nagawa mo na sa city? ano yung model ng city mo at sa anong points mo kinabitan? may city sx8 din ako and balak sana maglagay ng grounding kit. any noticeable differences?
    #52
    masubukan nga minsan. makapaghanap na muna ng mga gamit. hehehe.
    saslamat!
  13. #53
    yebo: ano ginamit niyong pang crimp? pwede na ba yung pliers? thanks
    #54
    malaki yung gamit kong connectors at #4awg yung wires, di kaya ng pliers o kahit vise grips. e ayaw ko naman bumili ng malaking crimping pliers para lang dun so ginawa ko nag-melt ako ng konting solder dun sa connector then pasok yung wire, then nung tumigas na e di martilyo! BAM! BAM! BAM! ayos siya higpit na ehehehe! for good measure nilagyan ko solder para mas maganda contact.
    Feb 2007
    #55
    Detailed explanation sa club website namin:
    http://kiaprideclub.proboards55.com/...ead=1169622375
    Mar 2007
    #56
    up ko lang. is this really effective? when my AC turns on, dumidilim ang headlights ko at kapag mag bass ang audio ang dilim ng ilaw ko lalo na yung dome light parang nagiging xmas lights. ang busina ko rin pumipiyok kapag nag oon ang AC
    will this fix the problems? ang rpm ko rin tumatalon talon kapag bumabaho eh
    Aug 2005
    #57
    Quote Originally Posted by suysuy View Post
    I think it will. Why not try it. Magiging responsive car mo esp electrical components system. Here's mine on my Innova:
    Mar 2007
    #58
    is that DIY or bought from a shop? mas ok ba ready made nalang? less hassle pa. kabit nalang agad
    Aug 2005
    #59
    Installed in a accessory shop. Less hassle nga kung doon ka na lang magpa-install. It is ready made naka pack na. But would you know where to bolt the terminal ends to strategic points inside the engine bay?
    Jun 2006
    #60
    Question po. Whats the difference of installing a grounding kit from the so called big 3 upgrade in car audio?
    The big 3 involves:
    1. upgrade of battery + cable to alternator +
    2. battery negative to chasis
    3. engine ground to chasis
grounding kit
