Results 61 to 70 of 70
May 9th, 2008 06:49 PM #61
usefriendly,
im not sure ha. pero from the looks of it, pag nag grounding kit ka na, number 1 of the big 3 ka na lang. kasi yung number 2 meron na sa grounding kit. although im not too sure of number 3, alam ko may kits na meron na ito, meron naman wala.
Tsikot Member Rank 4
- Jun 2006
- 2,605
May 9th, 2008 11:53 PM #62Thanks Morrissey. Yun din ang intindi ko pero di ako sure.
Ano pala wire size para sa 140 amp alternatorLast edited by userfriendly; May 10th, 2008 at 12:08 AM.
May 10th, 2008 03:13 AM #63
sorry medyo po makulet...i'd like to try this for myself and medyo matagal na yung mga previous posts so baka di na applicable sa present time...saan po ang mga points ng mga connectors coming from the negative pole of the battery? or isang straight connection lang paikot? btw carb po ride ko
TIA
May 11th, 2008 12:36 PM #64
magkano ba magagastos sa ready made? meron ako nakita 2k plus. mahal na ata ito dba? kung DIY magkano ba?
August 30th, 2009 04:51 PM #65
mga sir. i had a hyundai grace 2005 given by my parents, mejo wla akong idea e, stock lahat and i think my mga problema sa groundings nya since mahina ang mga ilaw, medyo di na rin maganda ang milage. magkakaron kaya ng overall improvements kung magpapalagay ako ng grounding kit? ano ano po kayang improvements ang makukuha ko? thanks!
August 30th, 2009 05:47 PM #66
Does this improve the life span of the battery? I had one installed in my Innova since 2005. I haven't changed the stock Oriental battery for 4 years na. Ever since, one click lang ang startup ng engine. Very bright ang headlights (or maganda lang talaga yung headlight assembly ng Innova?).
- Sep 2009
- 3
July 15th, 2010 03:00 AM #67wala pang effect sa idling o sa rpm especially during start up?
hindi ba ng exceed ng 1000 rpm?
esp. pag on nang aircon or headlight or radiator fan...
- Dec 2008
- 39
December 16th, 2010 12:29 PM #68
December 16th, 2010 12:35 PM #69
- Jul 2010
- 570
December 18th, 2010 04:35 PM #70Buti nabanggit mo iyan. Bihira naglalagay dyan ng ground wire. Pero para sa mga Distributor na built-in ang ignition coil at ang electronic ignition circuit ay may advantage ito dahil sa kaha ng distributor ang ground path at magandang direct connect sa (-) battery. Posible kasi magloose ground contact sa turnilyo ng distributor sa body ng engine. Kahit maganda ang ground connection nito. Mas maganda ang direct connect ng ground ng distriburior sa (-) Battery.
Mapansin mo improve ang starting at performance ng engine mo pag ginawa mo ito lalo na sa mga lumang kotse.
Looks like TGPH silently edited the article and removed the entry for Velocita Motors/Ferrari.
Car Sales Data (2024)
