Page 4 of 4 FirstFirst 1234
Results 61 to 70 of 70
    Apr 2004
    #61
    usefriendly,
    im not sure ha. pero from the looks of it, pag nag grounding kit ka na, number 1 of the big 3 ka na lang. kasi yung number 2 meron na sa grounding kit. although im not too sure of number 3, alam ko may kits na meron na ito, meron naman wala.
    Jun 2006
    #62
    Thanks Morrissey. Yun din ang intindi ko pero di ako sure.
    Ano pala wire size para sa 140 amp alternator
    Jan 2008
    #63
    sorry medyo po makulet...i'd like to try this for myself and medyo matagal na yung mga previous posts so baka di na applicable sa present time...saan po ang mga points ng mga connectors coming from the negative pole of the battery? or isang straight connection lang paikot? btw carb po ride ko
    TIA
    Mar 2007
    #64
    magkano ba magagastos sa ready made? meron ako nakita 2k plus. mahal na ata ito dba? kung DIY magkano ba?
    Jun 2009
    #65
    mga sir. i had a hyundai grace 2005 given by my parents, mejo wla akong idea e, stock lahat and i think my mga problema sa groundings nya since mahina ang mga ilaw, medyo di na rin maganda ang milage. magkakaron kaya ng overall improvements kung magpapalagay ako ng grounding kit? ano ano po kayang improvements ang makukuha ko? thanks!
    Jan 2008
    #66
    Does this improve the life span of the battery? I had one installed in my Innova since 2005. I haven't changed the stock Oriental battery for 4 years na. Ever since, one click lang ang startup ng engine. Very bright ang headlights (or maganda lang talaga yung headlight assembly ng Innova?).
    Sep 2009
    #67
    wala pang effect sa idling o sa rpm especially during start up?
    hindi ba ng exceed ng 1000 rpm?
    esp. pag on nang aircon or headlight or radiator fan...
    Dec 2008
    #68
    pwede sir. kahit diesel pwede. in case of carburated engines or diesel it's just to improve the elctrical grounding para mas maganda charging ng alternator at fully grounded ang starter motor. plus better grounding for the ignition system for the gas engine. ang connections will be sa alternator, engine block, car body and battery negative terminal lang, wala na sa intake manifold.
    sa efi and auto tranny it gives better performance for the ecu.
    -gas engine. ang connections will be sa alternator, engine block, car body and battery negative terminal lang
    -Sir puwede po rin bang magkabit sa distributor body????? thanks
    #69
    Quote Originally Posted by Boz View Post
    Sir, baka pwede pa-PM kung anong brand at kung saan niyo nabili yung grounding kit niyo. Pati na rin pala price. Salamat!
    Humihina kasi ang reception ng stereo tuner ko kapag ino-on ko na HID ko.
    Jul 2010
    #70
    Quote Originally Posted by Tatchest View Post
    Buti nabanggit mo iyan. Bihira naglalagay dyan ng ground wire. Pero para sa mga Distributor na built-in ang ignition coil at ang electronic ignition circuit ay may advantage ito dahil sa kaha ng distributor ang ground path at magandang direct connect sa (-) battery. Posible kasi magloose ground contact sa turnilyo ng distributor sa body ng engine. Kahit maganda ang ground connection nito. Mas maganda ang direct connect ng ground ng distriburior sa (-) Battery.
    Mapansin mo improve ang starting at performance ng engine mo pag ginawa mo ito lalo na sa mga lumang kotse.
grounding kit
