Results 1 to 5 of 5
September 19th, 2016 03:35 PM #1
Drove for 15mins and got the Powertrain Warning Light, it just stays ON not flashing.
Nothing unusual happened. Have it checked on a local shop on my way. They checked engine bay.
The Powertrain warning light is off while being scanned. Got a code U0001 result.
Mechanic said it maybe just a "PMS Reminder", which is indeed overdue but I doubt that caused did a little research and the U0001 Code has nothing to do with the Powertrain Warning Light.
It was reset, I drove for 30 mins 80-100kph and the warning light doesn't come on anymore.
What do you think?
Thanks in advance!
- Sep 2009
- 387
September 19th, 2016 03:51 PM #21. No, the warning light does not need to be ON when using OBD scanner. Errors are recorded to the ECU, this recorded errors are the one being read by the OBD scanner.
2. Sometimes, sensor contacts are misaligned due to vibration, etc .. In this case it should not be an issue. What you can do is observe, do not push your engine too much.
September 19th, 2016 04:27 PM #3
Thanks for the quick reply, that was a relief. I thought otherwise.
Will do observe for now until I can bring it to the dealership.
September 19th, 2016 04:36 PM #5
Thanks! Yeah, first result on google and made me think that the powertrain warning wasn't scanned by the mechanic.
well, i have never met a victim admitting they maltreated their trans box...
The Toyota Fortuner has landed (fortuner pics at...
