Results 1 to 19 of 19
    Jun 2011
    Good day! I do we have this (Quick Release Battery Terminals) here in the Philippines?
    Please point me out the store kung saan po meron.
    please see attached.
    Thank you!
    Jul 2016
    Meron sir sa ace hardware sa mga malls. Pero hindi ganyang type. Mukhang mas heavy duty yang nasa pix above.
    Sent from my SM-J500G using Tsikot Forums mobile app
    Feb 2009
    the battery post was not designed for reconnection/disconnection everyday if that's what you are trying to do. try a battery disconnect tool instead to minimize the wear and tear on the battery post and possibly breaking the terminal strap below the post.
    Heavy Duty Battery Isolator Switch 12V to 5V 2 amp *HEAVY DUTY BOAT/MARINE* | eBay
    Jun 2011
    Thank you so much Sir! You answered me well!
    Quote Originally Posted by X-salta View Post
    Try concored, I think their small car stuff are better than ace or babae sa mga nag set up ng sounds.
    Jun 2011
    KUDOS to you sir! God bless po.
    Why do you need a quick release terminals for battery. Doesn't look safe. Masyadong open baka dumikit pa and mag short
    Sep 2014
    Ang mahirap naman sa battery buhatin hindi turnilyuhin
    _________________________________
    If you are wrong, turn right.
    If you are right, turn left.
    Jun 2011
    I didn't say intend to connect it and reconnect it every day. Anyways... Thanks for the reply. I just need to know where to buy this kind of terminal.
    Thank you for your concern. I'm aware of this. Thanks for the reply. I just need to know where to buy this kind of terminal.
    I don't need this kind of reply... Thanks for the reply anyway. I just need to know where to buy this kind of terminal "that's all" * minicarph: NO NEED FOR STUPID ANSWERS.
    Sep 2014
    Pag lumuwag yan quick release na yan in time, tas nag high voltage ang battery sa redondo, tiyak sira alternator or ECU
    Jun 2005
    Popcorn mode na ba? =)
    Feb 2009
    Hse har har may tawad pang sabaw
    Jun 2011
    Quote Originally Posted by Janemar View Post
    Pwede.. Its just a glorified Q.R. terminal and much more expensive if I may add..
    Sep 2014
    Ah 'lam ko na hindi mo sa car gagamitin yan, sa photography no?
    Jul 2016
    Thank you!
    Ace/concorde/blade brands, not so good quality.
    Yung mga nag sosound set up na shops like autoline makati can hook you up with good quality Q.R. batt terminals.
    Feb 2009
    Maybe a battery isolator is what he needs
    batter isolator - Google Search
    Jul 2016
    Jun 2011
    * jick.cejoco: this terminals will do sir. thanks!
    Jun 2011
    okay sir. I'll try to give them a call. thanks!
