Results 1 to 10 of 19
February 6th, 2011 02:45 AM #1
I often use low-maintenance batteries, and I often find myself running out of the distilled water being sold by car battery stores. I was wondering if I can use Wilkins/Absolut as a replacement since they're much more accessible and convenient...?
BANNED BANNED BANNED
- Dec 2009
- 607
February 6th, 2011 08:50 AM #3
February 6th, 2011 09:36 AM #4
- Oct 2010
- 240
February 6th, 2011 11:38 AM #5I also use distilled drinking water in my Battery.
For Radiators, Coolant and/or the recommended mixture/ratio.
February 6th, 2011 04:24 PM #6
i think its somewhere in the owner's manual that coolant is recommended for the radiator, now some people don't have access to coolants at the time they needed to put fluid into their radiators, they opt for the next best thing.... distilled water, when we say distilled it means free of minerals which are common in regular tap water, which in turn may damage the radiator and engine block in the long run due to corrosion because of its(water) mineral content, so better use mineral free (distilled) water when coolant is not available, imho
- May 2010
- 15
February 9th, 2011 03:49 PM #7
Pre I just want to clear your idea. Im not saying that your idea is wrong, I just want to share this knowledge, mineral water / distilled water for radiator coolant is not good. why? because as what you say this free from any minerals that can be found in water. thus this kind of water will have a lower boiling point, plus it will react with the electricity running to your system ( Yes there is electricity conducting in every pipe and the body of your engine ) so in the long run it will result to electrolysis which can cause corrosion to any part of the radiator and engine. And it will be prone to sulfate which will create salt and will hardened and block the passage of radiator. Compare to Tap water which contains lots of minerals which can help cooling.
But if you used coolant it is much better if you use distilled water.
This information came from OAT Seminar conducted in singapore.
and it focuses in coolant.
- Jul 2003
- 2,267
February 9th, 2011 04:59 PM #8i am not a chemist but:
yes, distilled water has lower boiling point than tap water.
no, distilled water does not conduct electricity as much as water with minerals.
another thing, water (more so distilled water) is a universal solvent. it can dilute a lot of liquid / dissolve lots of minerals without any kind of chemical reaction. so i am not sure it will create salt inside the radiator.
on the other hand, if you use tap water, the mineral content tends to get concentrated over time as water slowly evaporates out the cooling system. at high concentrations, these minerals will crystalize and will clog your radiator.
can any chemist / chemical engineers confirm this?
- Dec 2009
- 607
February 9th, 2011 05:41 PM #9
Hard Water deposits when using Tap Water. Distilled water does not do this.
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
