Results 1 to 10 of 15
- Dec 2009
- 5
December 5th, 2009 04:28 PM #1yung car ko honda civic vtec 3 2002 model. hindi kasi gumagana ung low beam nya. pg high beam ok nmn. tnry ko na i tap directly s baterya to check kung ok pa ung bulbs. ok p nmn. bigla nalang kasi nawala yun habang ngdrive ako. ano kaya most probable cause non? and san kya recommended shops na kaya gawin un. ngtry kasi ako sa banawe ang gusto e irewire n agad, tapos palitan ko dw ng mas mataas n wattage ng bulb. pag mas mataas dw kasi wattage hindi daw kayanin ng stock n wiring. masusunog lng daw un. padvise nmn. thanks.
December 5th, 2009 04:40 PM #2
Baka naman pinalitan mo na lowbeam HL mo tas di mo napalitan yung wiring mo at nasunog ?
Totoo sinabi sayo, pag mas mataas wattage at stock pa rin yung wiring mo. Sunog talaga yan
- Dec 2009
- 5
December 6th, 2009 03:49 PM #3hindi pa ko nagpalit ng HL. basta bigla nalang nawala un habang nagdrive ako. medyo ang hirap nga mgbyahe sa gabi kasi high beam lang pwde. hassle sa mga kasalubong na sasakyan. ano kya possible reason and san maganda ipacheck and pagawa?
December 6th, 2009 05:50 PM #4
Sa auto electrical shop mo dalin mas kabisado nila tungkol sa lighting system ng sasakyan at wiring nito .Madali nila ma trace kung bakit ayaw gumana iyong low beam mo.
December 6th, 2009 06:14 PM #5
Original bulbs since 2002?
Mostlikely it is a busted bulb, one of the filaments may have been busted due to normal wear and tear, lalo na if you run on low beams all the time like I do. Buy a new set.
- Dec 2009
- 5
December 7th, 2009 10:59 AM #6
- Aug 2006
- 21
- Jan 2005
- 445
December 11th, 2009 07:31 PM #9
jeromealbert,
your headlight system uses one headlight relay for the LH and one relay for the RH side. they both share the same grounding point G401. if the headlight works on high beam, it means the relays are okay and the ground 401 is okay. the problem lies in the combination switch. if you have the patience and tenacity to take it out of the car and clean the contacts, 99% of the time the low beam problem is solved.
jick
December 11th, 2009 07:42 PM #10
This is the corect way to clean/wash microfiber towels The Correct Way to Wash Microfiber Towels |...
Cleaning Microfiber Towels?
