Page 2 of 5 FirstFirst 12345 LastLast
Results 21 to 40 of 83
    Dec 2009
    #21
    Kanina while leaving nag start naman hiace ko no problem. Then biglang tumirik di pa ako nakaka layo. Then nag series ako at nag start pero naka ilaw battery light. Possible ba na battery lang problem neto? 2sm battery neto more than 2 years na. Thanks
    Sent from my SM-J730G using Tapatalk
    To check get a voltmeter..with engine running the voltage reading should be => 13.5V. That would mean a working alternator
    Get a voltmeter attached to ur cars lighter plug like cathy did
    Also get a portable battery jump starter and keep it fully charged
    Those are the things you need to keep you from stalling on the road with defective electrical car components
    Sent from my GT-P3110 using Tsikot Forums mobile app
    #22
    Nakakadrain din ba ang obd2 reader kapag naka attach siya tapos naka tengga ang sasakyan?
    Dec 2009
    #23
    ^To check set the car key to OFF, then check on your phones bluetooth if it will be detected
    Mar 2004
    #24
    Alternator voltage should be at least 14V to charge battery properly ... 14.7 V is the ideal charging voltage ...
    Jan 2009
    #25
    Is that measured pre or post regulator?
    Voltage across the battery terminals should eventually stabilize to around 13.8 float charge voltage. If the charging voltage is higher than this even after the battery is already fully charged, it will definitely reduce its life. Flooded cell batteries should be maintained at 2.25 to 2.27V float charge per cell once full.
    Optionally, people can invest on an in-vehicle battery tester that will test both the battery condition and charging system. Either that, or just drop by a Motolite shop and have the same tested for free.
    Dec 2017
    #26
    Search "battery tester" in olx or lazada.
    From the other thread about battery, I asked if is possible to just use a multimeter to check the battery health instead of a hygrometer.
    Upon searching about this battery tester, I saw a video explaining​ how to use a voltmeter to check how healthy your battery is. It said that normally, voltmeter reading will be 12 and once you crank your engine it will read below 12. You should not have a reading below 10 volts while starting the car. Below 10 means your battery is about to "give up". Once the engine is running, you should have a reading of about 13-14 volts.
    My question now is, how can you check the battery without cranking the engine and by using only a multimeter? Is this even possible?
    #27
    yes and no.
    you have to challenge the battery's ability to give out a heavy current. cranking does that. they even ask you to turn on all your headlights and aircon.
    if you check the battery without challenging it, you will probably still get a 12 volt reading, even if the battery will die the next day.
    with the engine running, you are now measuring the alternator's output, which is 13-14 volts. you are not measuring the battery's output.
    they also test this, because, in many instances, the battery is dying because the alternator is defective.
    yes, it is possible to check a battery that is not even connected to the car.
    in older shops, the gadget they use has a large resistance wire that glows lightly, mimicking the starter's high current drain.
    i am assuming, electronic instruments that do not glow hot in the dark, can do this. i used to have a cigarette lighter meter, that warns me of my battery's condition.
    i'm eager to hear from kim. i am more historical. he is more up to date.
    #28
    some taxis have a sideline. they have jumper cables, and will jump dead batteries for a fee.
    "open your engine hood", as a signal.
    Dec 2009
    #29
    A battery is made up of 6 cells, each cell is about 2.1V
    6x2.1V = 12.6V, thats the peak voltage of a healthy battery
    When an engine is started the starter draws current from the battery. Thats known as loading (starter) the source (batt). When current is drawn from the source the voltage of the battery source will sink (go down). Thats the nature of the battery with and without a load.
    Now if a cell of a battety deteriorates, the peak voltage of 12.6V will go down to 10.5V. Each cell that dies on a battery reduces the voltage by 2.1V.
    If cranking the starter reduces the voltage by 2V. A healthy batt with 12.6V will sink to 10.6V for an engine to start. A batt with dead cell will have a 10.5V to begin with will sink to 8.5V once the engine is started. As more cells die the battery becomes weak and no longer useful to start an engine and replaced
    So a voltmeter is an uncommon tool found on cars. Refitting one is a good move for any car owners. Its the best companion in any travel to monitor the health of your car battery
    Complement it with a portable jumpstarter and always keep it charged could be a charm when your battery begins to show signs of failing.
    Dec 2009
    #30
    I have seen some did so out of sheer goodwill
    Its the appreciative private car owners who express their token of appreciation by offering monetary rewards to a kind gesture
    #31
    older design batteries allowed for individual checking of cells. the defective cell(s) can be isolated and replaced or re-built.
    vehicle owners on a thin budget still do this.
    #32
    that's nice.
    but jumper cables are not factory spec. someone has to purchase them.
    but yes. there are good-hearted folks out there.
    also, jumper cables go both ways.
    ang puj, walang jumper. tulak lang sila. push-start. dahil walang starter ang iba.
    if you notice, many pujs have bumper hits. not because they got into accidents, but because, to them, push-start is a way of life.
    Dec 2017
    #33
    Thank you for this explanation! Now this answers my question why those battery shops will buy your busted battery. They can make a "reconditioned​ battery" by exchanging the dead cells.
    I always bring my portable charger and jump-start battery. Unfortunately, I gave my portable battery to my brother. I suppose I can buy a new one.
    For a cheapskate like me, I don't want to buy this battery tester if it is possible to check my battery with my multimeter. I don't want to put something​ that is not OEM, as much as possible, as I consider it as "clutter".
    I think I should have bought a clamp meter instead of this multimeter. The only reason I bought this is for our project, we needed to measure the room temperature. I was thinking that a multimeter is a handy tool but I'm​ thinking now that a clamp meter is better. I can simply turn on the car without starting the engine. In that way, I can monitor the current. The question is, the "correct value" of Ampere reading.
    yes and no.
    To justify my purchase of this "expensive" five thousand peso multimeter, I hope to get a detailed guide on how to make the one that you mentioned. The ones I found in the internet is too complicated​ for me or just not OEM for me or I just​ didn't search thoroughly enough.
    Dec 2009
    #34
    that's nice.
    I saw the taxi driver used a simple housing electrical cable and it worked
    Portable jumpstarters dont have a heavy duty cable as well..large clips but smaller diameter than the commercial jumper cables
    Portable jumpstarters are not simple cables..its a small battery with electronics and cable clips to jumpstart a stalled engine with a weak battery
    #35
    jumpstarters.
    jumpstarter cables.
    two different things.
    #36
    for testing ordinary circuits, home and auto, buy the cheap ones at handyman or ace. less than 500 pesos. i have both analog and digital.
    "they'll do."
    i prefer the heavier model, as the unit sometimes gets carried away by the leads.
    the one you have pictured here, the manurfacturer put in all those pictures on the box, to impress the prospective buyer.
    Jan 2009
    #37
    Clutter? What are you talking about?
    "In-vehicle" means that the tester is used with the battery still installed/connected to the vehicle. It checks the overall battery condition, like internal resistance, cold cranking Amps (CCA), etc., and gives a report on the state of health (SOH) and state of charge (SOC) of the battery (0-100%) along with other information. The same tool is also used to check the charging system of the vehicle (with instructions to raise the engine RPM to a certain speed while it does its measurements). With that, it also provides the ripple voltage (indicates how well the voltage from the alternator is regulated and filtered), etc.
    The measurements below is from my 3 y/o Innova Diesel.
    Using a multimeter alone is not the right tool for the job. Voltage measurements does not reflect what is happening inside the battery or your charging system at a granular or detailed level. A "dead" battery could exhibit 12+V open circuit with a multimeter. But as soon as you connect it to a load and current starts flowing, internal resistance comes into play and will then cause the battery voltage to drop below usable levels.
    Dec 2017
    #38
    Clutter
    I'm referring to the ones plugged in the cigarette lighter. I thought you were talking about that one, my mistake. In that case, regarding the multimeter, I might just leave that at home and buy the one that you posted.
    I thought​ I can get away with that multimeter. That means​ it will be inside the cabinet for most of the time...
    Feb 2014
    #39
    "they'll do."
    i just googled that DMM. it's loaded. measures light, sound, temperature, humidity. but personally i prefer separate devices
    Dec 2017
    #40
    Quote Originally Posted by Vodka View Post
    Yes, because we needed to measure lux intensity and room temperature all at the same time. The lux intensity x1 and x10 are inconsistent. Other than that, everything works fine.
    EDIT: That multimeter is user friendly, the slots will lit up for you to know what socket you should use and will emit an audible sound should you put it on the other slot. Of course, this is not idiot proof.
Battery drain.
