Results 11 to 16 of 16
August 21st, 2006 03:01 PM #11
just want to add some questions and info from fellow tsikoteers...
kung sakaling palakihan ko ang battery A, kailangan bang palitan din ang alternator?
any useful links bout this.....
thanks a lot
- Mar 2006
- 57
August 22nd, 2006 12:47 AM #12not necessary if you dont modify or add electrical load to your battery.
pero pag pinalakihan mo battery mo coz nagdagdag ka ng electrical load (sounds, alarm, electronic device, etc) you need to upgrade also you alternator para hindi ma undercharge battery mo... dapat maibalik ng alternator yung nawala o na discharge from battery
- Mar 2006
- 57
August 22nd, 2006 01:00 AM #13mamar: observe your battery kung mabilis mag discharge kahit d ginagamit... kc baka ala namang problem sa battery mo ngaun. either kc magpalit ka ng battery w/ the same size kung talagang sira na battery mo ngaun or upsize ka ng battery baka d kaya yung load mo.
August 22nd, 2006 10:53 AM #14
2 years na pala eh. palitan mo na yan. add to the fact na di ginagamit everyday kaya di nagchacharge regularly. maybe what you can do is replace your batt tapos kapag long stretches na di ginagamit yung car, start one every 3 days for mga 5-10 minutes para makapagcharge siya.
August 22nd, 2006 09:59 PM #15
salamat mga bosing tingin ko battery na nga kasi kanin pag park ko nung oto tinaas ko ng sabay sabay ung 4 na window tas nung pag tingin ko sa volt meter mula sa 14 naging 12 nalang tas nung naka taas na ung mga windows dahan dahan nang tumaas ulit ung volts ulit sa 14!
tas napapansin ko din po sa oto ko pag medyo mahina ung battery edi mahirap po mga start tas pag nag start na biglang mag aalar pag ka start nung oto! bakit kaya?
lagi lang po kasi ako busy kya hinde ko pa ma pa check ung oto eh!
- Aug 2006
- 1
August 29th, 2006 09:56 AM #16I have a similar problem.. On my way home yesterday, the battery indicator turned on. But my car still started when I turned off the engine and started it again. I had it checked today at a Motolite shop in Espana thinking that the battery is the problem, (its already 2 yrs plus old) but the shop told me that it's the alternator that has a problem not the battery. My car is a 96 mitsubishi galant V6 automatic. Can you give me some suggestions?
Where can have it checked?
If in case I need to buy a new alternator how much is a brand new and a surplus?
Thanks !
i wonder, are the usual published suspension adjustment specifications supposed to be adjusted...
Wheel Alignment
