Page 107 of 115 FirstFirst ... 75797103104105106107108109110111 ... LastLast
Results 2,121 to 2,140 of 2297
    #2121
    Hindi pa yan plugged sa outlet when I took the picture.
    ilan hours na patay engine bro?
    mas ok kasi if CCA rating makita, pero if 12 hours na patay engine and ganyan ang reading ibig sabihin nag retain parin ng charge.
    btw ganyan new charger ko pero 6A version, lintek sa kupad mag charge hahaha
    Sent from my Redmi Note 9 Pro using Tsikot Forums mobile app
    #2122
    Hahaha wala ako alam sa ganyan.
    BTW 4 days ng patay ang engine [emoji23]
    #2123
    Here’s mine, checked it kanina.
    how long have you had it?
    does it work, i.e., de-sulphate sulphated batteries?
    Jan 2009
    #2124
    We have four of these, two mobile and two semi-permanently mounted.
    #2125
    ah 12.7v eh good yun batt mo bro
    #2126
    Sulit. Mag 3 years na din.
    #2127
    Napapaisip tuloy ako if I should replace the battery of my 11th gen na. It 5 1/2 years already but I am curious if it will beat my 10th gen's record. Ang issue ko lang, sa 10th gen ko, saan man ako abutan pwede ako pa push start kasi manual, e yung 11th gen ko a/t
    Jan 2008
    #2128
    suggestion lang po.. replace the capacitors inside with a good / durable brand.. yung sa tropa ko pumutok agad yung caps.. replaced with a good one.. ok na
    #2129
    I believe na if it ain’t broke why fix it?
    Mura lang naman ito, first time to buy a car battery charger. If ever masira will consider buying yung pricey na mas matibay tibay na.
    Still thank you sa suggestion [emoji16]
    #2130
    did the friend mention how much it cost him to replace them caps?
    and yes,
    some caps do last long.
    it's a gamble, what the buyer gets in his purchase.
    Jan 2008
    #2131
    and yes,
    when he plugged the charger, he heard a pop sound then the charger went dead.. upon inspection, main cap in the DC output popped.
    i replaced the caps.. bought at an electronic shop for 80 petot.. i forgot the brand but its a known brand.. given the same ratings, the new caps are larger compared to the stock caps installed in the charger.
    you can really see that the caps are made up to spec and quality materials.. not like the stock caps installed in the device
    Jan 2008
    #2132
    more like an upgrade po.. the charger design is good naman.. its just the stock caps in DC output needs to be replaced with a good one for better performance.
    or don't leave the charger unsupervised.
    #2133
    perusing lazada,
    i saw a similar-looking charger as the yellow one here.
    it costs 399 bucks.
    Jan 2008
    #2134
    yup its really cheap charger.. good design naman at yung electronics na "smart".
    price wise, goods na.. i don't know if may factor yung battery size being recharged.. kasi yung sa friend ko 3sm battery yun recharged nya..
    sa CTEK charger, sa initial phase of charging, you can feel the connectors and wires getting warm
    #2135
    larger capacity batteries just take longer to charge, that's all.
    if built well, chargers used within their parameters should have not trouble lasting long.
    if "not built well"... heh heh.
    #2136
    Which amaron is often being referred to in this thread? Hi life, go or pro. I'm being offered hi life for 4900 and go for 4000 net of 200 trade in. I'm now coming off Emtrac, after several Motolite golds. Emtrac lasted longer than my Motolites, but I don't know it's equivalent with Amaron.
    Sent from my Mi A1 using Tsikot Forums mobile app
    Ano nangyari sa emtrac mo sir?
    Ramdom question. Are DIN type batteries and JIS type (1SM/2SM/3SM) interchangeable? Assuming that the ah, and cca are higher?
    Apr 2009
    #2137
    Ang isang maaaring concern ay yung physical dimensions ata sir.
    Sent from my XQ-AS72 using Tapatalk
    #2138
    totoo bang walang akmang battery ang amaron para sa mga expe or nambobola lang iyong seller kasi wala siyang stock?
    Jan 2009
    #2139
    "expe" = Expedition?
    What battery does it have now (make and model)?
    Model year and trim of your vehicle?
    #2140
    G65 kasi ang Expedition, wala talaga si Amaron bro.
Amaron battery
