Results 1,251 to 1,260 of 2282
July 29th, 2016 01:21 PM #1251
- 54,220
July 29th, 2016 02:30 PM #1252the 11.9 volts is the battery's innate voltage. but as all voltmeters have an inherent +/- accuracy value, say, 10%, the actual voltage can be anywhere between 10.71 volts to 13.09 volts.
once the engine starts, the 13-14 volts measured is actually the alternator's output and not the battery's.
how can you get a more accurate reading? get a more accurate, usually also much more expensive, voltmeter.
July 29th, 2016 06:09 PM #1253
Dropped by handyman a while ago to check on batt chargers and the only brand available is panther. Charges 6 and 12 volt batts. It's priced at under 2k
Sent from my ASUS_Z00AD using Tsikot Forums mobile appLast edited by baludoy; July 29th, 2016 at 06:44 PM.
- 54,220
July 29th, 2016 06:34 PM #1254
- Aug 2012
- 2,767
July 29th, 2016 10:08 PM #1255
- Aug 2012
- 2,767
July 29th, 2016 10:11 PM #1256
July 29th, 2016 10:30 PM #1257
^ automatic meaning stop na siya mag-charge kapag kargado na iyong batt mo?
saan mo siya nabili pala bro?
- Aug 2012
- 2,767
July 30th, 2016 09:35 AM #1258Yes, correct. It is an automatic smart multi-stage battery charger. Kapag puno na ang battery, it will switch to floating charge mode. You can keep the charger connected or remove it when you want. Sa D3 din.
D3 Technologies | Facebook
Sent from my D5833 using Tapatalk
- Aug 2012
- 2,767
July 30th, 2016 09:36 AM #1259Ganito operation nya:
1. Recovery stage - pulsed charging recovers deeply discharged batteries
2. Bulk charge stage - high then medium charge rate to reach 80% capacity.
3. Absorption stage - low charge rate until 100% capacity.
4. Maintenance stage - drop in voltage will trigger floating charge to maintain full charge.
- Oct 2014
- 162
July 30th, 2016 01:45 PM #1260
I agree. travelling by train is always the fastest way to travel. kami din dati sa Bangkok, we...
Makati Subway. Completion date: 2025
