Just replaced my stock battery (1 year, 2 months old) with an Amaron 2SMF. I got it from Metrobat in Makati. The person I spoke with the night before (Max) was very helpful. He offered some suggestions why my battery was being drained after two days of not being used. He also said I could drop by Metrobat to have my battery checked.
So I went there the next morning and another guy (forgot his name) started "diagnosing" what my battery's problem was. After five minutes of testing, he said his hydrometer broke and couldn't test the water level. He also said my battery seemed OK, except that the voltage was constantly dropping.
To cut the story short, Metrobat couldn't tell me whether my old battery was fine or whether it was time to change it. The guy said the only way to find out was to disconnect the battery and wait for two days to check if there's a significant drain. I had checked my electrical system for parasitic drain and everything was normal based on my own tests (0.03A drain with everything off). Anyway, I decided to replace the stock battery with Amaron to avoid any more headaches and keep my sanity.
So the guy replaced it. In the process, he lost one of the clips of my air duct and I was forced to look for a replacement. I noticed the clip I had wasn't identical and I couldn't screw it in. I left it with him and soon after everything was in order. Or so I thought. I found out later that he had forced it in and it took 10 men to pry it off. But we're getting ahead of ourselves.
During the next four days, I noticed that my fuel consumption wasn't going above 4km/L. I suspected something wrong about my engine bay, and sure enough, I found out that my air duct wasn't completely seated because one of the metal hooks holding the Amaron battery in place had not been correctly installed and was jutting out, lifting the air duct and causing it to be slightly disconnected. I just fixed it myself. That was when I found out the clip holding the air duct onto the chassis had been forced in.
So if you're planning on getting an Amaron, I wouldn't recommend Metrobat. Find another dealer just to be on the safe side.
