Page 19 of 20 FirstFirst ... 9151617181920 LastLast
Results 361 to 380 of 385
    Sep 2004
    #361
    OEM batteries, 1.5 years at least bro...All have been replaced and I have a bank here ready for them.
    I guess I am lucky with my 5 sets...
    Thanks bro. I already replaced the battery last night the reading of the dead battery is 2.70v. The fresh battery reads at 3.33 v,
    I will observe again kung gaano ang itatagal netong new battery.
    Jul 2004
    #362
    How long did your OE sensor last? Yung ibang OE batteries ok pa?
    It went kaput on the 3rd year, IIRC.
    Apparently you cannot just replace the battery of the unit. You have to replace the whole unit, toink
    Jul 2004
    #363
    300 or 350 lang ata binayad ko sa vulcanizing shop.
    How much was the sensor? Or you can replace just the battery of the sensor?
    Sa MS, the sensor is sealed and you cannot replace the battery. Pampapera talaga ng Winterswine ito
    #364
    Sa rim ata yung sensor Kasi Di ko naman pinalitan yun. Not sure how the TPMS works on the ASX but yung 3 valves pinalitan ko na.
    #365
    Ito ba yung mga sensors na naka-install sa loob ng rim? If so, how much did it cost you to replace one?
    Sa MS ko, I was quoted Php9,000 for a single replacement. I said forget it and went aftermarket. No regrets ever since.
    Kahit bagong external TPMS ang bibilhin ko taon taon, mura pa rin
    Same with me bro. After the batteries of the oem internal tpms sensors of our MS died after 2 years, I did not bother replacing them. I just bought a new set of tpms and its external sensors...
    #366
    Quote Originally Posted by lancepower View Post
    In my experience, my tpms sensors stop transmitting when the battery is at 3v... Needs to be higher than that.
    #367
    sakin bro as high as 3.09v intermittent na
    Jul 2013
    #368
    Guys, any leads kung saan makakabili ng matibay na tire valve/pito (preferably online).
    Yung lock kasi ng TMPS ko ay nakaka strip ng thread ng barbula. Masyado malambot yung valve.
    Dec 2008
    #369
    Quote Originally Posted by Lew_Alcindor View Post
    Stainless tire valve sir mg ask ka sa mga auto shop meron nyan sa akin deretso ko na pinapalitan doon sa shop and tire balancing na rin medyo mabigat na kasi tire valve.. so far so good pag hinigpitan ko tpms di na sumasama tire valve. Yung dati kasi na rubber tire valve pag higpit ng tpms pg dimo kinontra medyo ma stress yung rubber tirevalve.
    Sent from my Nokia 7 plus using Tsikot Forums mobile app
    Jul 2013
    #370
    Quote Originally Posted by john042776 View Post
    Salamuchas gracias!
    Jan 2008
    #371
    kung may silicone grease, pwede nyo lagyan yung rubber o-ring para hindi matuyot..
    Dec 2008
    #372
    Yes sir salamat sa advise
    pwede ba bumili ng set of external sensors lang? nginatngat kasi ng huskey namin iyong top part nung isang sensor. kaya ngayon jerry rigged covering lang nilagay ko using a lot of electrical tape.
    flushed type iyong monitor kasi sa dashboard ( sa foglamp switch provision siya installed) iyong nilagay ko sa auto kaya hindi basta basta mapalitan lang iyong buong unit.
    Sep 2016
    #374
    Check po sa seller kung nagbebenta. Parang may nakita ako noon sa lazada seller na nagbebenta ng sensors lang. Di ko na mahanap eh.
    #375
    ang alam ko,
    they by set, not by the piece.
    but good luck, po.
    Jan 2009
    #376
    It's one thing na makahanap ka ng exact replacement sensor. Isa pang magiging problema is kung may paraan na ma-pair mo sa receiver.
    Nov 2019
    #377
    Hindi ba to mananakaw?
    The X3 has a built-in tpms and connects to the mid display.20221220_105317.jpg
    you speak the truth brother
    Ang salarin sa pag ngatngat Ng sensor Ng kotse. Maski tinakpan ko na Lang Ng electrical tape, may Plano pa din balikan ata Kasi tinabihan nya nanaman iyong gulong [emoji850][emoji29][emoji2959]
    Sent from my RMX3690 using Tsikot Forums mobile app
TPMS (Tire Pressure Monitoring System)
