Page 36 of 39 FirstFirst ... 263233343536373839 LastLast
Results 351 to 360 of 385
    #351
    The tpms set on our 2 vehicles are at least 3 years old na and i haven't experienced any slow leak due to damaged tire valves.
    Will keep an eye on those na lang din.
    Same in my case bro... I have 4 sets of external tpms with each at least 4yo and no issue so far other than battery replacement... On the side and could be a factor, I am the only one who is mounting and dismounting them. Will keep these in mind though....
    Aug 2021
    #352
    Pwede malaman brand sir? Lazada?
    Sent from my SM-A315G using Tapatalk
    Dec 2008
    #353
    Just an update ito yung stainless tirevalve ko na worth 130pesos s shop mismo binili, ang observe ko na kaibahan nya sa rubber is pag hinigpitan mo yung tpms sensor kahit dmo alalayan yung tirevalve ok sya matigas...img_20211222_192752.jpg
    Sent from my Nokia 7 plus using Tsikot Forums mobile app
    #354
    Quote Originally Posted by QUEZ View Post
    IIRC, Zeepin bro. Yes, Lazada.
    4 external sensors and a receiver that is plugged into the cigarette lighter interface. The receiver displays the vehicle voltage, tyre pressure in psi or bar, the tyre temperature in degC or degF... It gives a soft(but high pitched) audible alarm if any of the tyre pressures is outside of your defined limits and if the vehicle voltage is below 12v or something...
    Cost iirc was P1.5K to P1.8K...
    Sep 2004
    #355
    How long does the battery in the sensor last? I bought my tpms last September 2021 just after a month the battery
    of the f-r sensor already died. I replaced it with Panasonic cr1632 batt and just today wala na rin (3 months & 4 days).
    Btw I already replaced also the battery of r-l and f-l sensor last Nov and Dec 2021. Ang natitirang original battery na lang
    ay yung sa r-r sensor (going 4 months on Jan 28)
    #356
    Quote Originally Posted by lancepower View Post
    OEM batteries, 1.5 years at least bro...All have been replaced and I have a bank here ready for them.
    I guess I am lucky with my 5 sets...
    #357
    I have already replaced three of the valves in the ASX. Maybe the 4th one needs replacement anytime soon. Built-in yung TPMS ng ASX sa HU nya.
    Jul 2004
    #358
    Ito ba yung mga sensors na naka-install sa loob ng rim? If so, how much did it cost you to replace one?
    Sa MS ko, I was quoted Php9,000 for a single replacement. I said forget it and went aftermarket. No regrets ever since.
    Kahit bagong external TPMS ang bibilhin ko taon taon, mura pa rin
    #359
    How long did your OE sensor last? Yung ibang OE batteries ok pa?
    #360
    300 or 350 lang ata binayad ko sa vulcanizing shop.
TPMS (Tire Pressure Monitoring System)
