Results 1 to 10 of 36
July 15th, 2007 12:27 AM #1
guys!
san kaya pwede magpagawa ng automatic open ang trunk kapag pinipindot sa remote ng alarm i mean sa may keyless entry and how much? matanong ko lang since madaming mga alam ang mga tao dito. thanks! where and how much? salamat againnn!
July 15th, 2007 12:39 AM #2
afaik, kung may provision yung central-door-lock system mo para sa boot/trunk locks, ang main na gagastusin mo na lang e actuator para sa trunk lock mo. which is IIRC PhP250.00/pc. or pwede mo rin i-tap dun sa isa sa mga rear doors mo.
hth
BANNED BANNED BANNED
- 3,790
July 15th, 2007 04:22 AM #3kung walang provisions sa keyless entry switch mo e hindi uubra yan...but you can do a button switch sa dash board instead.
nurse on wheels
- Dec 2006
- 392
July 15th, 2007 04:32 PM #4i'm currently using autopage rf-315 which has a separate button for trunk release. what i did was i had a trunk release motor installed in the trunk lid, next to the trunk release cable. it works just like a normal actuator but it's specifically for the trunk release. then the electrician wired it to the alarm module. it works great. however, if your alarm system/keyless entry doesn't have a dedicated button for trunk release then it won't work. there's a way around it just like the previous posters said, which is to tap from one of the doors however when you open your doors using the remote, your trunk will open too. you might forget that it's open and that could be disastrous. putting a separate switch on the dash would be redundant since i suppose you already have a trunk release switch.
July 15th, 2007 06:15 PM #5
bro newbie lang po. i can't understand your terms. so kung may separate button ka sa remote pwede magpa install? i mean buttons that are not used. kasi sa remote ko may 2 buttons dun na wala naman purpose pwde nila ikabit dun? how much po?
nurse on wheels
- Dec 2006
- 392
July 15th, 2007 10:43 PM #6the extra button on the remote should be specifically for the trunk release. it usually has an icon resembling an open trunk. if your remote has this then good for you. if not, then maybe adding an actuator to pull the trunk release cable would work but it would have to open simultaneously with the other doors of the car when you press the unlock button. however, the actuator for the 4 doors is different from the trunk release actuator in the sense that the former has push and pull functions, the latter only pulls. by pressing the lock button on the remote, your trunk won't lock automatically, you will still have to push it down until it locks. looks like i'm rambling, my bad. anyways, easiest solution i can think of is to get a new alarm, the cheap autopage rf-315, then add a trunk release actuator. the trunk release actuator costs around 1000 pesos including installation. hope this helped.
July 15th, 2007 11:08 PM #7
On some systems, you can access the auxillary function (e.g. roll windows, pop trunk, illuminate dome lamp, etc.) by holding down a button for an extended period of time. On older, two-button Viper anti theft systems, you accessed the auxillary function (trunk popper in this case) by holding down button II for more than 3 seconds.
- 3,790
July 16th, 2007 11:00 AM #9
July 16th, 2007 01:22 PM #10
AFAIK, kahit wala kang TRUNK RELEASE button sa alarm e pwede. Kaya ng installer yan na lagyan ng delay ung unlock button ng alarm para pag hinold mo for 3 secs. e magta-trunk release ung trunk mo. Of course, you still need an actuator, pero di mo na kelangan ng alarm na may trunk release button.
Slight disadvantage lang e magaunlock talaga ung mga pintuan mo, pero ilalock mo rin naman pagkasara ng trunk kaya oks lang. Eto ginawa sa Lancer ko nung bumigay ung stock alarm na may trunk release at pinalitan ng aftermarket.
wow thank you for your very informative reply, should i stick with the old 80's Mercedes to have...
Alternative Fuel Source: Waste Vegetable Oil...
