Results 1 to 20 of 36
    Jun 2007
    guys!
    san kaya pwede magpagawa ng automatic open ang trunk kapag pinipindot sa remote ng alarm i mean sa may keyless entry and how much? matanong ko lang since madaming mga alam ang mga tao dito. thanks! where and how much? salamat againnn!
    Apr 2006
    afaik, kung may provision yung central-door-lock system mo para sa boot/trunk locks, ang main na gagastusin mo na lang e actuator para sa trunk lock mo. which is IIRC PhP250.00/pc. or pwede mo rin i-tap dun sa isa sa mga rear doors mo.
    hth
    kung walang provisions sa keyless entry switch mo e hindi uubra yan...but you can do a button switch sa dash board instead.
    i'm currently using autopage rf-315 which has a separate button for trunk release. what i did was i had a trunk release motor installed in the trunk lid, next to the trunk release cable. it works just like a normal actuator but it's specifically for the trunk release. then the electrician wired it to the alarm module. it works great. however, if your alarm system/keyless entry doesn't have a dedicated button for trunk release then it won't work. there's a way around it just like the previous posters said, which is to tap from one of the doors however when you open your doors using the remote, your trunk will open too. you might forget that it's open and that could be disastrous. putting a separate switch on the dash would be redundant since i suppose you already have a trunk release switch.
    Jun 2007
    bro newbie lang po. i can't understand your terms. so kung may separate button ka sa remote pwede magpa install? i mean buttons that are not used. kasi sa remote ko may 2 buttons dun na wala naman purpose pwde nila ikabit dun? how much po?
    the extra button on the remote should be specifically for the trunk release. it usually has an icon resembling an open trunk. if your remote has this then good for you. if not, then maybe adding an actuator to pull the trunk release cable would work but it would have to open simultaneously with the other doors of the car when you press the unlock button. however, the actuator for the 4 doors is different from the trunk release actuator in the sense that the former has push and pull functions, the latter only pulls. by pressing the lock button on the remote, your trunk won't lock automatically, you will still have to push it down until it locks. looks like i'm rambling, my bad. anyways, easiest solution i can think of is to get a new alarm, the cheap autopage rf-315, then add a trunk release actuator. the trunk release actuator costs around 1000 pesos including installation. hope this helped.
    Quote Originally Posted by rockstaremya View Post
    ... i can't understand your terms. so kung may separate button ka sa remote pwede magpa install?...
    if it is like this -
    Attachment 8791
electronic trunk open
