Results 11 to 20 of 20
- Jun 2015
- 37
September 18th, 2017 01:38 AM #11
September 18th, 2017 06:49 AM #12
Electronic parking brake behvior while moving probably depends on the make and model of the vehicle.
What Happens If You Pull The Electronic Parking Brake WHILE driving ? - YouTube
September 18th, 2017 10:41 AM #13
Power steering these days are electronic ... accelerator pedal has been electronic for a decade already ... these are not physically connected anymore ... they are drive by wire ...
Mercedes Benz tried electronic braking system on the W211 E-class but consumers did not like it and reverted back to analog during the facelift of W211 model ...
September 18th, 2017 10:43 AM #14
September 18th, 2017 11:02 AM #15
I agree with you, but that's not the point I'm making.
Yes, we have electronic steering assist and drive-by-wire accel pedal.... but they're still analog. Obviously, you can't have a steering system that can only do full left, right, and center. Same with the accel and brake pedals. They're not simple ON and OFF switches.
As opposed to shifting... where gear selection is fixed. Even cars with CVTs, the driver does not have override control over the gears.... if it has 7 forward gears, you can select 1 to 7, but not 1.5, 3.8, or some other odd gear ratios that, in reality, the CVT could probably do in "D".
Same deal with electronic parking brakes... it's either ON (engaged) or OFF (disengaged). How often have ordinary people actually used their parking/e-brakes in an actual emergency? And wouldn't you think that activating a button is easier for everyone than tugging on a traditional lever, where locking the rear tires is possible? Not everyone drifts.
- Jan 2008
- 4,726
September 18th, 2017 11:46 AM #16
September 18th, 2017 12:02 PM #17
Actually, instantaneous ang response ng drive-by-wire. Any inherent delays are designed and controlled by the ECM (ie. "rev-hang"), depending on the current driving conditions.
The pedal-to-throttle ratio is not always 1:1. This is very prominent sa A/T with drive-by-wire. If you put the pedal to the metal while in D, you will notice that the engine rev will "hang" near where the next shift point is, giving you a smoother transition to the next gear with little shift-shock and engine still within its powerband.
Kung 1:1 yun and you take off at WOT, you will experience a lot of shift-shock and hindi magtatagal yung A/T.
- Feb 2014
- 2,711
September 18th, 2017 12:11 PM #18i think people are confused w/ electric vs electronic. analog vs digital
electric refers to things moved by electricity. e.g. electric power steering is assisted by electric motors. which is controlled by a bunch of electronics. that's the crucial distinction here. that's why you shouldn't say electronic power steering
as for drive by wire accel pedal it's actually digital. the pedal position sensor encodes and communicates the position as well as a whole bunch of checksums, error-correction, etc. it's not safe to transmit this as an analog signal, interference would cause SUA-like disastersbut that's not to say digital systems don't go SUA coz they do if they're buggy LOL
September 18th, 2017 12:18 PM #19
Semantics lang... electric/electronic power steering means the same thing. It's essentially a giant servo/stepper motor... which is controlled electronically... to provide just the right amount of torque.
And sa accel pedal... Yes, it is digital under the skin, but the manner in which it is operated is analog. Again, semantics na lang. An analogy (no pun intended) is digital music. Yes, the music is encoded digitally, but when you listen to it, it's analog.
- Feb 2014
- 2,711
September 18th, 2017 12:43 PM #20well i'm telling you it's wrong to call a Tesla an "electronic car"
continue to do so and you immediately lose credibility LOL
they're called electric cars. clear naman yung distinctionpinoys are just so sloppy w/ terminology kaya nga walang progress diba
A relative of mine in Canada had his Scion FR-S PPF'd and then had it ceramic coated. He says it's...
Ceramic Coating vs PPF (Paint Protection Film)
