Problema natin ngayon eh how to secure our vehicles against carjacking right? Well I have some ideas which might help some of our tsikoteers who do not have enough budget to puchase those expensive alarm systems. Please take note na I will merely present the concept as it will be dangerous to show in this forum on how to do it step by step. On how you will do it? Use your imagination!!!!
DIY Project No. 1:
Marami sa mga car ngayun ang may automatic lock ng doors pag nakatakbo ng at least 25 km/h. You can take advantage of that by putting a relay with a resistor sa fuel pump at yung automatic lock naman ang magiging trigger para sa armature ng relay. Siyempre pag may carjacker off mo muna ang car para ma reset ang automatic lock. Pagandar nila at pag apak ng 25km/h ng speedometer ayun magsisimula ng magcountdown ang makina ng at least 20 seconds before maubos yung gas sa may fuel filter. That will give you approximately 50 meters of distance from the carjacker. Teka bakit may resistor? Hehehe! Cost of project: Php 300.00
DIY Project No. 2
Ano ba ang common sa mga manual at automatic pagdating sa transmission? Ano pa eh di yung reverse light switch! Same din ang concept gaya ng DIY Project No. 1, ang reverse light switch lang ang papalit as trigger dun sa armature ng relay . How to use? Simple, pag na flag down ka make sure to park in such a way na kailangan pa nilang i reverse ang sasakyan. Bakit kailangan uli ng resistor dito? Hehehe! Cost of project Php 300.00
DIY Project No. 3
Ano pa ba sa loob ng car ang hindi mo pinapansin? Ano pa eh di yung mga driver/passenger lights as well as yung interior light switch! Same concept din. The relay resistor (can be dispensed with). Pag dumating ang carjacker magbigay galang ka. Turn on the interior lights! Eh papaano kung pinatay ng carjacker ang light pagkakuha ng car? Yun nga ang silbi ng resistor eh. Bakit ko naman sinabi na pwedeng tanggalin yung resistor? Kasi pwede mo ring tanggalin yung bombilya para kunwari eh sira. Will it work kung nakadefault sa gitna yung interior light switch? Syempre! pagbukas mo pa lang ng pinto eh nagsisimula ng mag-countdown ang fuel reserve mo basta ba huwag mong kalimutan yung resistor. Php 300.00
DIY Project No. 4
Saan pa ba pwedeng i-tap? Hand break? Syempre coz meron siyang park light! Items relay and resistor. Php 300.00
DIY Project No. 5
How about power windows? Opo pwede dahil may power window lock siya. Php 300.00
DIY Project No. 6
Sa mga hindi mahilig magbusina katulad ko. Pwede ba ang busina? syempre naman! Eh papaano kung kailangan kong magbusina? Eh di maglagay ka ng separate switch para sa busina mo! Php 300.00
DIY Project No. 7
Teka puro electrical ang mga nasa itaas, wala na bang mechanical? Meron po. Question: pagnacarjack ka ano most likely ang mga gagalawin ng carjacker? manibela, pedals at stick? correct! Meron na tayo sa manibela at sa stick kaya sa pedals naman tayo. Siguro naman mas matagal gagamit ng preno ang carjacker kaysa sa clutch at accelerator di ba? So pag preno niya magsisimula nang magcountdown yun. Items: relay, resistor, separate switch. Bakit may separate switch? By-pass po yun. Php 350.00
DIY Project No. 8
Papaano kung hindi ako marunong ng electrical or mechanical? Siguro naman marunong kang magdasal noh![]()
