Results 11 to 20 of 25
November 11th, 2005 11:10 AM #11Originally Posted by ghosthunter
Round 2. Possible din, pero hindi kaya abutin din ang gas tank mo?
November 11th, 2005 11:12 AM #12Originally Posted by zero
Tsikot Member Rank 4
- 2,716
November 11th, 2005 11:59 AM #13Originally Posted by jimaroquai
However, the idea is cool. Using 1kV might be enough to give a painful shock and insulation would be manageable.
November 12th, 2005 09:43 PM #14
mga pare, interested ako sa mga idea nyo. it's cool at mahilig din kasi ako sa mga ganito. tanong ko lang mawawala ba ang waranty ng car kapag nagkabit ako ng mga relays. TIA
BANNED BANNED BANNED
- 3,790
November 12th, 2005 10:37 PM #16maganda ang most ng concept assuming pababain ka kaagad sa oto mo na kinarjack. as mentioned papaano kung isinama ka muna?!?
I am thinking na what if you control these fuel shut-off valves with a remote switch (just like the keyless entry remote) na hidden sa belt or pants mo (remember the old style pants na merun secret pocket?).
So you would "arm" your delay switch sa fuel shut off valve when you get off the vechicle...sisimple ka lang sa bulsa or sa belt mo when they left you off na.
OR
A remote switch na meron proximity sensor...so as long as the nearby ka the shut-off valve will be on. Pero pag napalayo ka na, mag-ooff na ito. Hindi ko lang alam kung meron nang ganitong electronic kits available.
- Nov 2005
- 15
November 12th, 2005 11:14 PM #17Tama! Paano nga kung isinama ka muna at na-trigger na ang DIY mo??? Sabi nga ni Bitoy: "Yari ka!" Pero kahit hindi ka isinama, 50 meters lang? Ang mangyayari pala, pag-iwan sa iyo, dapat karipas ka talaga ng takbo in the opposite direction ala the Flash! At kung may back-up car o motorcycle na kasama, "Yari ka na naman!"
Nice ideas though kaya lang di ako marunong ng electrical/mechanical. Baka pwede pa-demo naman.
November 15th, 2005 05:35 PM #18Originally Posted by wildthing
ano ang idea dito? pagbaligtarin ang use nila. Use the 2nd part sa armature ng relay. Tanggalin yung tweeter at connect it to the armature ng relay. but you have to look for a low voltage armature which can react to at least 1.2v of power. yung 1st part naman ang ilagay mo sa secret pocket mo.
Voiding warranty:
Relays are not that destructive. Kung nagkamali ka, you will only fry P10 pesos worth of fuse which you could easily replace. Just dont work your way towards the ecu.
In case na isama ka:
Well, you could consider putting a second switch sa gitna ng second row seats where you could have access.
50 meters is not enough:
Gayahin ninyo ako, I always drive with my rubber shoes on. Para mabilis ang takbo ko kung sakali
- 3,790
November 16th, 2005 04:18 AM #20hindi lang naman siguro 50 meters yun bago mag-stall ang oto...dahil nag-run out ng fuel..... ok yun key chain tweeter na yan...
