Results 1 to 10 of 20
- Sep 2015
- 16
March 29th, 2016 10:40 PM #1tanong ko lang po regarding sa car alarm beep. binasa ko yung manual ng car alarm ang naka lagay kapag nag unlock ka 1 beep tapos 2 beep naman kapag nag lock ka.ang scenario naman sa akin kapag nag unlock ako eh 3 beep ang tumutunog minsan naman ay 2 beep.diba dapat 2 beep lang sya.kadalasan kasi beep eh ang nakalagay sa manual kapag 3 beep it means na may hindi naisara maigi sa pinto eh tinignan ko naman lahat ng door nakalock naman sya ng maayos.ano po kaya ang problem kapag ganun? code alarm po gamit ko ca1053 po thanks.tapos pala minsan kapag mag unlock na ako eh minsan ayaw gumana bago pa naman yung alarm key.
- Jul 2008
- 7
June 12th, 2016 01:38 PM #3
- Apr 2010
- 131
December 7th, 2016 09:25 PM #4Na solve mo na ba ito? Just sharing, had the same problem. My car has dome light dimming delay. Na solve ko after reading ca 1053 installation manual regarding dome light dimming delay.
The system can be programed to delay arming after the lock button is pressed (60 second max) for vehicles with a dome light delay or theater dimming feature. Once programed the system will ‘learn’ the timing of the dome light delay and add 2 seconds before arming.
1. Close all doors with ignition off.
2. Using the transmitter press LOCK, UNLOCK, LOCK ,UNLOCK, LOCK , UNLOCK, LOCK. The LED will light solid to indicate the system has entered DOME DELAY LEARN MODE.
3. Immediately OPEN then CLOSE the door WITHOUT disarming the system. The system will then monitor the door trigger wire. Once the dome light turns off, the system will then add 2 seconds and then exit the learning mode.
4. The LED will begin to flash indicating the system has exited the learning mode and is now armed.
- Aug 2012
- 104
February 7th, 2017 11:28 AM #5
- Oct 2013
- 1,181
- Aug 2012
- 104
February 7th, 2017 02:27 PM #7
- Oct 2013
- 1,181
March 2nd, 2017 10:45 PM #8Paps, as per manufacturer, try to make no. 8 DIP switch from ON to OFF. Yan yung door ajar warning.
- Apr 2017
- 7
April 7th, 2017 11:34 AM #9
- Aug 2012
- 104
June 22nd, 2017 09:47 AM #10Sa fortuner sir pero ok na pinalipat ko sa door switch mismo para maging 1 chirp lang paglock/armed
Sent from my GT-I9500 using Tapatalk
Right? People will really start questioning the need for the EDSA rehabilitation.
EDSA Rehab/Rebuild and Guadalupe Bridge Repair
