Results 1 to 20 of 20
    Aug 2012
    Quote Originally Posted by aloy View Post
    Na solve mo na ba ito? Just sharing, had the same problem. My car has dome light dimming delay. Na solve ko after reading ca 1053 installation manual regarding dome light dimming delay.
    The system can be programed to delay arming after the lock button is pressed (60 second max) for vehicles with a dome light delay or theater dimming feature. Once programed the system will ‘learn’ the timing of the dome light delay and add 2 seconds before arming.
    1. Close all doors with ignition off.
    2. Using the transmitter press LOCK, UNLOCK, LOCK ,UNLOCK, LOCK , UNLOCK, LOCK. The LED will light solid to indicate the system has entered DOME DELAY LEARN MODE.
    3. Immediately OPEN then CLOSE the door WITHOUT disarming the system. The system will then monitor the door trigger wire. Once the dome light turns off, the system will then add 2 seconds and then exit the learning mode.
    4. The LED will begin to flash indicating the system has exited the learning mode and is now armed.
    Sir same lang din ba ito sa ca 3051?pwede ko iapply?mine is 3 chirps armed then 2 chirps disarmed pero ang nakalagay sa manual 1chirp armed 2chirps disarmed..paano po iadjust ito..thanks
    Sent from my GT-I9500 using Tapatalk
    Oct 2013
    Quote Originally Posted by Seagull_615 View Post
    Ano car nilagyan mo pasp ng CA3051?
    Aug 2012
    Quote Originally Posted by vvti2.0 View Post
    2014 fortuner sir upgrade lang
    Oct 2013
    Paps, as per manufacturer, try to make no. 8 DIP switch from ON to OFF. Yan yung door ajar warning.
    Apr 2017
    sir, did this resolve your issue? also madali lang ba gawin if ever you were able to resolve the issue? i have the same ca3051 issue in my new innova e.
    thanks.
Car Alarm Beep Question?
