Results 3,431 to 3,440 of 3510
March 20th, 2021 07:38 PM #3431
I think pasok pa yan sa Blueskysea B1W. Old model pero should work fine
Sent from my SM-N986B using Tsikot Forums mobile app
- Mar 2021
- 636
March 20th, 2021 10:01 PM #3432
- Oct 2012
- 4,851
April 17th, 2021 03:20 PM #3433Viofo parking mode.... sino naka pag set up dito?
Sa akin pag enable ko ang parking mode and set to only event occurs, nag rerecord siya continously kahit naka park lang...
kaya ni turn off ko muna ang parking mode baka ma ubosan batt ko...
- Feb 2008
- 97
April 20th, 2021 05:27 AM #3434may naka pry open na ng Transcend DP200 dito? after 4 years sakin sira na battery gusto ko sana e check and if possible palitan if may battery avail sa shopee.. wala ko makita sa youtube for tut pag tanggal.. wala din screws yung unit..
- Jan 2008
- 4,726
April 20th, 2021 09:07 AM #3435
- Feb 2008
- 97
- Jan 2007
- 2,633
April 23rd, 2021 08:18 PM #3437Anyone tried this? I've been thinking about using a powerbank as a buffer for dashcams.
Just need to find one that's auto-on when the charger circuit is connected.
12V switched -> 5V stepdown -> USB powerbank -> dashcams 1&2
Powerbank should charge when the vehicle is turned on, then provide power to dashcams even during extended park time (like now with lockdown).
- Nov 2019
- 1,443
April 24th, 2021 12:53 AM #3438Nice idea.
But Im not sure if the electric power from car is enough to full charge the powerbank.
Yung powerbank ko dito, need to stay overnight para mag fullcharge.
Sa auto kasi if to/from office lang, ave 30 mins lang siya sa daan unless if traffic talaga.
It might not be enough to power dashcam if lowbat powerbank.
If hindi lowbat powerbank, OK yung idea.
If lowbat, need mo tanggalin from car to charge overnight sa bahay
April 24th, 2021 11:23 AM #3439
You need a battery combiner.
Combiner 100 Sheet
This will allow you to have the batteries work independently when not charging. When the car is running, both batteries are being charged. When stopped, both batteries will work independently and won't drain each other.
I suggest using an SLA battery (sealed lead acid) for your dashcam, unless you can find a space in the engine for it.
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
