Anyone tried this? I've been thinking about using a powerbank as a buffer for dashcams.
Just need to find one that's auto-on when the charger circuit is connected.
12V switched -> 5V stepdown -> USB powerbank -> dashcams 1&2
Powerbank should charge when the vehicle is turned on, then provide power to dashcams even during extended park time (like now with lockdown).
You need a battery combiner.
Combiner 100 Sheet
This will allow you to have the batteries work independently when not charging. When the car is running, both batteries are being charged. When stopped, both batteries will work independently and won't drain each other.
I suggest using an SLA battery (sealed lead acid) for your dashcam, unless you can find a space in the engine for it.
