Page 172 of 176 FirstFirst ... 72122162168169170171172173174175176 LastLast
Results 3,421 to 3,440 of 3510
    Jun 2015
    #3421
    Note lang na 70mai uses a battery, not a capacitor. Medyo notorious ang battery na madaling masira. Natuto na ako sa last dashcam ko kaya ngayon ina-unmount ko yung dashcam pag naka-park sa bahay at exposed sa araw.
    Maganda ang mounting ng 70mai. It uses mounting tape on an electrostatic film that you "stick" to your windshield. Madali rin syang i-slide out from the mounting clip.
    Nov 2019
    #3422
    Thanks for this info! Yung GPS at speed collision hindi ko naman kailangan so ok lang ako sa cheaper variant.
    Pwede pa share nung shopee link kung saan mo nabili? Puro 3k+ yung nakikita kong price kasi ngayon sa shopee
    Attachment 38009
    Eto yung link but sold out na pala and then na replace na ng A500 model.
    https://shopeedotph/product/129632888/2695576569
    Note: Just change "dot" to .
    Jun 2015
    #3423
    Pa-phase out na siguro yung nabili mo kaya mura na ang benta. Yung mini ko rin mabilis naubos after kong makabili.
    May A800 na kaya malamang nag-uubos na lang ng stocks ng A500 ang sellers.
    Jul 2013
    #3424
    Planning to install a rear facing dash cam (hirap na, madami kasi bikers sa daan)
    As I already have a front facing cam
    Do I:
    1. install a new system na connected yung front and rear facing camera?
    or
    2. just buy another standalone camera tapos install ko to face the rear?
    Viofo... finally arrived... 12k including shipping and 32gb sd card... [emoji106][emoji106][emoji106] time to replace my xiaomi...
    Mar 2021
    #3426
    Anong magandang entry-level dashcam na capacitor, around 2k php or less?
    Need palitan yung Yi dashcam na nasira na sa extra car at nakabilad sa araw. Pero nakatakip naman ng windshield sunshade when parked.
    Ayaw na mag-on ni Yi dashcam, cheap lang kasi
    Try to look for ddpai with solid capacitor...
    Mar 2021
    #3428
    ^ Thank you sir!
    Btt, my transcend drivepro in my daily drive is still alive after 4 years. Pero kaput na battery
    Nov 2017
    #3429
    Kahit anong dashcam ata madali masira kung palagi nakabilad sa araw
    Yup... pero solid capacitor can go longer compared to battery dash cam...
    Dec 2004
    #3431
    I think pasok pa yan sa Blueskysea B1W. Old model pero should work fine
    Sent from my SM-N986B using Tsikot Forums mobile app
    Mar 2021
    #3432
    Quote Originally Posted by thephantom View Post
    Thanks for the suggestion for the b1w
    Viofo parking mode.... sino naka pag set up dito?
    Sa akin pag enable ko ang parking mode and set to only event occurs, nag rerecord siya continously kahit naka park lang...
    kaya ni turn off ko muna ang parking mode baka ma ubosan batt ko...
    #3434
    may naka pry open na ng Transcend DP200 dito? after 4 years sakin sira na battery gusto ko sana e check and if possible palitan if may battery avail sa shopee.. wala ko makita sa youtube for tut pag tanggal.. wala din screws yung unit..
    Jan 2008
    #3435
    Quote Originally Posted by baju83 View Post
    capacitor yata sir ang gamit ng transcend.. may nabibili nung capacitor sa shopee
    #3436
    thank you sir!
    #3437
    Anyone tried this? I've been thinking about using a powerbank as a buffer for dashcams.
    Just need to find one that's auto-on when the charger circuit is connected.
    12V switched -> 5V stepdown -> USB powerbank -> dashcams 1&2
    Powerbank should charge when the vehicle is turned on, then provide power to dashcams even during extended park time (like now with lockdown).
    Nov 2019
    #3438
    Nice idea.
    But Im not sure if the electric power from car is enough to full charge the powerbank.
    Yung powerbank ko dito, need to stay overnight para mag fullcharge.
    Sa auto kasi if to/from office lang, ave 30 mins lang siya sa daan unless if traffic talaga.
    It might not be enough to power dashcam if lowbat powerbank.
    If hindi lowbat powerbank, OK yung idea.
    If lowbat, need mo tanggalin from car to charge overnight sa bahay
    Dec 2017
    #3439
    You need a battery combiner.
    Combiner 100 Sheet
    This will allow you to have the batteries work independently when not charging. When the car is running, both batteries are being charged. When stopped, both batteries will work independently and won't drain each other.
    I suggest using an SLA battery (sealed lead acid) for your dashcam, unless you can find a space in the engine for it.
    Dec 2017
    #3440
    Wow! I was able to post again.
    [emoji3]
Blackbox DVR/Dashcam
