Page 207 of 351 FirstFirst ... 107157197203204205206207208209210211217257307 ... LastLast
Results 2,061 to 2,070 of 3510
    Jun 2012
    #2061
    *CNS, you can also save a certain file manually by pressing a few buttons there. I will go down later so i can share it with you. I have been using DP220 for almost a year now but haven't used all its features.
    Btw, magkano bili mo? Igot mine for 5k before sa Megamall
    Mura nyan ah. Akala ko mura na kuha ko ng dp200 for 5k rin
    Sent from my SM-N930F using Tapatalk
    #2062
    Quote Originally Posted by dct View Post
    Emergency record rin. Just like recording pag nabangga. Pero di nya kailangan matrigger g sensor. Pindutin mo lang yan
    Okay bro copy hehe
    Mura ah! Saan yan? 7.5K bili ko tapos 100 na tip dun sa nagkabit hehe.
    Mamaya ko pa lang magagamit pag uwi.
    Sige bro pashare pag may tips ka pa.
    Salamats!
    #2063
    *bro cns
    naka-off lang ang g-sensor ko. sensitive masyado ang mga g-sensors kahit set mo sya at minimum, baka matambakan lang ang sd card mo ng protected files na hindi naman kinakailangan. 1080p kasi ang settings ko kaya malakas kumain ng memory. emergency record na lang. though accurate naman ang speed limit sensor, lane departure warning niyan. naka-set din yung frontal collision warning ko pero hindi ko pa sya nadinig na nag-warning. nasa 90kph yata kasi ang settings ko doon at wala pa naman akong na-experience na mabulaga sa distance during high way runs mula nung na-installed ko sya.
    parking mode? hindi ko pa nasubukan, naka-off lang ako. activated kasi sya thru motion sensor, gagamitin ko na lang sya kapag alanganin yung lugar na paparadahan ko.
    #2064
    Quote Originally Posted by benchman View Post
    *bro cns
    Yes naobserve ko nga, konting bumps record agad siya. Will turn it off na din tomorrow.
    Emergency record is manually pressing the red button?
    Just read the manual, kulang sa info bakit ganun? No features explained tsk tsk
    I already downloaded and installed the drivepro app, watched the recording via wifi.
    How come malabo? Or dapat download muna then watch? Or dapat ba sa pc/laptop ko ilipat at panoorin?
    How to activate the parking mode? Yan ba yung pag nagalaw/nabump yung sasakyan mag record?
    #2065
    Exposure ba dapat naka 0?
    How can you include your plate details sa video stamp? I explored it already, no options for that?
    Do you guys enable audio recording?
    Aug 2005
    #2066
    Exposure should be set to zero. -negative setting and beyond, your dc will record underexposed videos, while positive onwards will record overexposed. Zero is neutral. Sa qube A7 may option to save texts for video stamps. I ain't sure of features of other brands. I always set my dc audio ON.
    Sent from Zenfone2
    #2067
    Quote Originally Posted by leinahtan View Post
    Sent from Zenfone2
    Noted on this.
    Thanks bro!
    #2068
    emergency record; yes, press the red button lang. recording starts 10 seconds prior to the event you pressed the button then records 10 seconds more pa towards the event then saved as protected file.
    viewing thru wifi, medyo sketchie talaga sya. delayed pa. pero hindi naman sya con para sa akin dahil hindi ko naman sya ginagamit, pinurbahan ko lang.
    parking mode, browse mo lang sa settings bro. kung activated, mag-record sya kapag may na-detect na motion sa harap ng auto mo. it will record everything until the battery drains. occasional ko lang magagamit ang feature na 'to. kapag alanganin lang talaga siguro yun lugar na paparadahan ko.
    audio, naka-on na ako ngayon at the lowest settings. captured naman nya ang mga conversations kahit nasa low lang.
    this video might help you with the menu/settings;
    Oct 2015
    #2069
    Sir saan nyo nabili? Mura ha. Mas mahal pa sa Amazon.
    Feb 2005
    #2070
    Quote Originally Posted by Wh1stl3r2 View Post
    PC Worx sa Cyberzone Megamall.
    I browsed thru OLX then texted some of the sellers, meron dun na nakausap ko na willing to sell at 5k, then nag tingin ako sa Megamall, pasok ako PC Worx, tanong lang, sabi 5.5k daw, sabi ko may nag offer sa akin olx 5k, tinawag sa boss nila, pumayag naman kasi yun pala ka text ko sa OLX, sa tindahan din nila.
    Early last year pa yun. Actually, planning to buy another one, di pa lang ako nagagawi dun. Hopefully makakuha ulit ng mura or same price.
Blackbox DVR/Dashcam
