I've seen YouTube videos na may parang clear plastic na linalagay sa windshield bago idikit yung dashcam...
Has anyone installed something similar?
Tinted kasi windshield ko, if I use a suction, baka masira yung tint... Yung adhesive naman, hirap linisin kung maisip ko magpalit ng cam
Nic Chua - Really?!? Counterflowing na, singit pa! From... | Facebook
Bwisit na Adventure
Sent from my RNE-L22 using Tapatalk
Anyway, it's a good sample of the Yi Rearview Dashcam's rear camera.
I am using a blindside mirror to mount my dashcam, much reliable than plastic which react to heat and bulge overtime.
mas maganda parin talaga mini dashcam ni bro jut.
this is OEM vlt 35 already and sobra na clarity nito, borderline clear na IMO.
vkool oem VLT 35 (not much difference from VLT 20) - YouTube
eto no tint unfair comparo as well lit yun areas nadaanan, but you get the idea.
DDPAI no tint 1(5) - YouTube
Ano kayang quality dashcam na within 1-1.5k? Gagawin ko lang rear camera. Madami ako nakikita online pero sana yung magtatagal kahit di sobrang linaw.
anyone have (blueskysea?) B1W camera?
it's 1080p and capacitor based, no screen so settings and video review are done via wifi.
same form factor and hardware as the xiaomi 70mai but that has a battery.
the qube a7 i got 3+ years ago is starting to act up. might be fixed by replacing the battery pero i removed the windshield tint kasi so i think it affected the lifespan
it is in the 2k range, and an upgrade to the g1w-c cameras
Hi! Do you have any suggestions for a dash cam with most if not all of these features:
1. 3 cameras (front, inside, rear)
2. Good quality images/videos for both day and night (at least for front cam)
3. Can view recorded media remotely (via 3g or 4g)
4. Has LCD screen
TIA!
Sent from my SM-G950U using Tapatalk
You might want to check this out:
DIY: 360 Camera And Dashcam Setup - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Items 1,2, and 4 are covered. I haven't tried if item 3 is possible.
I'm contemplating to dismantle the "inside camera" and remove the frame because I find it too big. Another option is to replace the said camera with a smaller one.
Is a 128GB SD card enough to cover at least 12 hours of driving before looping back to the start and overwriting the existing videos? I am planning to document my drive from Manila to Mindanao if ever that will come to reality within the year.
I have checked the maximum memory it (DDPAI mini 2P) can handle and it says it can use up to 128GB max. Kapag mukhang matutuloy na yung trip namin, tsaka na lang ako bibili.
Thank you for the info sir. Pag long break siguro para kumaen, kunin ko na yung nasave na video para sure.
Bought junsun A930 dual camera... so far the interface seem responsive... i can use the rear camera just like the nissan terra feature pag puno ang likod you can still see who’s behind you... [emoji4]
Junsun A930 10 inch 4g support car gps navigation description - YouTube
Buksan mo lang enough yung A-pillar cover para malusot mo yung cable sa pagitan ng airbag and A-pillar. Bale sa driver side ako nagpadaan ng cable. Yung direction ng insertion ko was sa left side ng A pillar. Yung connector sa cable to dashcam ang nilusot ko then hatak nalang papunta dashcam. I did this sa CR-V with airbags on A-pillar
