Page 165 of 176 FirstFirst ... 65115155161162163164165166167168169175 ... LastLast
Results 3,281 to 3,300 of 3510
    #3281
    Quote Originally Posted by chronicle View Post
    The other question is, does your dash support 128gb?
    In my dashcam, a 5minute 1280x720 30fps vid consumes around 200mb.
    Just fill in the blanks:
    (zz) shots per hour x (yy) mb x (xx) hours = ? mb
    128GB was enough for ~14 hours of footage at 1440p, 30FPS on my dashcam.
    A119 Spytec or Viofo dashcam
    Sep 2016
    #3282
    I have checked the maximum memory it (DDPAI mini 2P) can handle and it says it can use up to 128GB max. Kapag mukhang matutuloy na yung trip namin, tsaka na lang ako bibili.
    Thank you for the info sir. Pag long break siguro para kumaen, kunin ko na yung nasave na video para sure.
    Jun 2019
    #3283
    About dascams - Action Cameras All results
    Oct 2014
    #3284
    Mga Boss
    Ano recommend nyo for dash cam worth 2K, more or less. Thanks
    Sep 2010
    #3285
    Quote Originally Posted by JJ All Day View Post
    Mga Boss
    Xiaomi Yi. Around P2.4k if I'm not mistaken.
    Oct 2014
    #3286
    Thank you.
    Mar 2019
    #3287
    Bought a 70mai Dash Cam Pro for our Toyota Rush, but the dealer says they won't install my cable since the camera didn't come from them. Hesitant to install the cable on my own because I might get in the way of the deployment of the side (curtain) airbags. Ano ang puwede gawin dito?
    Bought junsun A930 dual camera... so far the interface seem responsive... i can use the rear camera just like the nissan terra feature pag puno ang likod you can still see who’s behind you... [emoji4]
    Junsun A930 10 inch 4g support car gps navigation description - YouTube
    Jul 2013
    #3289
    Quote Originally Posted by EricDraven View Post
    Disconnect the battery?
    I've taken off passenger airbag in our Innova before. Simple lang. Disconnect lang connectors.
    #3290
    Quote Originally Posted by Lew_Alcindor View Post
    medyo intimidating lang sa una, pero tama ka bro di naman complicated. i guess ingat lang sya masira plastic locks.
    Ohhh... which area yung dangerous part na ma deploy yung airbaigs when installing dash cam wire?
    I have mine ecosport and cruze before pero im not aware na meron pala ganyan... now, i will try to install it in terra and cx5(soon) but with the post above i have to be carefull since both of them has curtain airbags ...
    #3292
    bro try mo nalang gawa ni jut
    ipit ipit sa headliner and sidings ng interior since di naman mabigat ang wires ng dashcam
    Mar 2019
    #3293
    https://i.imgur.com/5BL8qzx.png
    I'm particularly concerned about the area in green. I'm not keen on disabling the airbags to do this (sorry) pero ayoko din maharangan ang side airbag sa paglatag ng wire. I'm just not that sure whether running it down the side of the windshield will cause any interference.
    Parang same kami ni jut...
    Ganito yung set up ko previously... pero sa windhsield
    Area yung wire instead dun sa part ng passenger window side... naka tago lang dun sa plastic cover...
    Tapos sa rear cam ganito, sa baba ko dina.an...
    #3295
    there is a lot of space inside the A pillar. airbag "modules" are not that big.
    Installing Dash Cams on Vehicles with Airbags - BlackboxMyCar - YouTube
    Mar 2019
    #3296
    Ganyan nga din ang iniisip ko. I think I'll go with that.
    Thanks guys!
    Last edited by EricDraven; July 5th, 2019 at 05:08 PM. Reason: error in formatting
    #3297
    Buksan mo lang enough yung A-pillar cover para malusot mo yung cable sa pagitan ng airbag and A-pillar. Bale sa driver side ako nagpadaan ng cable. Yung direction ng insertion ko was sa left side ng A pillar. Yung connector sa cable to dashcam ang nilusot ko then hatak nalang papunta dashcam. I did this sa CR-V with airbags on A-pillar
    #3298
    Tape the dashcam cable onto the A-Pillar behind the airbag, if car is equipped.
    Mar 2019
    #3299
    Quote Originally Posted by marky2115 View Post
    Buksan mo lang enough yung A pillar cover para malusot mo yung cable sa pagitan ng airbag and A pillar. Bale sa driver side ako nagpadaan ng cable. Yung direction ng insertion ko was sa left side ng A pillar. Yung connector sa cable to dashcam ang nilusot ko then hatak nalang papunta dashcam. I did this sa CR-V with side curtain airbags.
    Kapatid, may portion ba yung airbag that deploys dun sa A pillar mismo kahit kapiraso lang? Meaning, sa kaso ba ng CRV bubuka yung plastic cover ng A pillar kapag gumana yung side curtain airbag?
    Mar 2019
    #3300
    Diyan ako medyo nangingiming magkalikot eh most videos sa YouTube ng naglalatag ng wire, isinusuksok lang yung wire along the crevice. Meron naman iba na nagtutungkab ng cover like what you did, pero hindi maganda ang track record ko sa mga pagbukas-bukas ng mga ganyan nakakatakot makabasag ng clip or whatnot, esp. with a car this new. But thanks for the image, it's a big help. Ano'ng oto ito?
Blackbox DVR/Dashcam
