Page 162 of 176 FirstFirst ... 62112152158159160161162163164165166172 ... LastLast
Results 3,221 to 3,240 of 3510
    Mar 2018
    #3221
    Quote Originally Posted by tsik_r2d2 View Post
    Planning to buy a dashcam po.. is rear dashcam really necessary considered I have rear cam naman po?
    Also, preferred ko po yung nasa likod lang ng rear view mirror.
    No idea with wiring so sana po yung easy install lang.
    Thanks for any inputs! :-)
    hi sir r2d2! magkaiba po kasi ang rear/reverse/backing camera sa rear dashcam. yung backing cam bale guide po sya dba pag magrereverse while yung rear dashcam nagrerecord po, just in case may bumangga sa likod eh may evidence po kayo. get a dashcam po na plug and play lang for easy installation.
    Jul 2013
    #3222
    sorry is this has been answered earlier...
    Normally, for brand new cars, mnag kano singil ng casa kung pa install ka ng dashcam?
    Sep 2005
    #3223
    you can buy a YI dashcam for under 3T and install it yourself.. tatago mo lang wires..
    Jul 2013
    #3224
    I know
    pero gusto ko sana sa fuse box galing yung power...
    #3225
    I know
    pwede naman kung gusto mo, gamit ka lang ng fusible tap/link.
    Mar 2007
    #3226
    Php1.5 singil sa akin sa Ford BGC. Kasama installation ng rearview camera and pagtago ng wires.
    Sent from my RNE-L22 using Tapatalk
    Quote Originally Posted by gromek View Post
    Fusebox na gamit?
    Jul 2013
    #3228
    I know
    I'll post mine pag-nagawa ko na.
    You just need a fuse tap (I bought 5pcs for 250 petot online) and couple of feet of wire.
    Instead of buying a hardwire power adapter, I'll just connect the existing power supply to the fuse tap (maybe solder for better connection).
    Youtube is my teacher for this.
    Jul 2013
    #3229
    ^marunong naman ako gumawa...
    kaso kung 1.5k lang (as mentioned above), pwede na...
    #3230
    Sayang 1.5k pang full tank na yan sa mga sedan na kotse ngayon.
    Jan 2008
    #3231
    I know
    yung cigarette lighter or accessory line ang best power source for dashcam..
    Mar 2007
    #3232
    Mahal nga pero dun ko na rin pinagawa para walang issue sa electrical warranty. Baka ma-void pa kasi. Nanigurado lang. Although malinis naman ang gawa.
    Jul 2013
    #3233
    "rearview camera" - as in reverse camera?
    Mar 2007
    #3234
    Yes sir. Yi Rearview Dashcam yung pina-install ko.
    Jan 2013
    #3235
    Magkaiba yung reverse camera at rear camera.
    Sent from my ONEPLUS A3000 using Tapatalk
    #3236
    balak kong pakabit nito, pero may mga comment na malabo daw lalo na sa gabi.
    Kindly share your experience bro.
    Mar 2007
    #3237
    Ok naman siya for me. Yung front cam similar sa quality ng trancend 230 ko na nakakabit sa other car namin.
    Yung rear not as clear but still ok. As a reverse cam ok naman siya.
    Jun 2018
    #3238
    Anyone who have tried Yi Mini dashcam? Okay naman day and night videos? Thanks.
    Mar 2018
    #3239
    I just bought from my neighbor the QCY A70 (Front and Rear Cam) 1080 Vehicle Blackbox DVR with a 32GB micro SD card for 1,700.00 only hehe. Ok naman for daytime recording but for night time, below average na lang. Sana durable naman . . .
    Jul 2014
    #3240
    I know
    you can connect to fusebox using the supplied cigar charger then hide the cables.
    you need a soldering iron and red and black wires about 6inches long.
    open the cigar charger then locate the positive and negative terminals
    solder the red wire to positive and black to negative
    reassemble the cigar charger with the two wires extending out.
    in the fusebox, locate the cigar lighter fuse and tap the red wire.
    connect the black wire to any metal screw under the dash.
    use cable tie to tighten loose cable and find a hiding place under the dash.
    check everything works by switching your keys to ACC or ON.
Blackbox DVR/Dashcam
