Results 1 to 20 of 3510
    Jul 2013
    sorry is this has been answered earlier...
    Normally, for brand new cars, mnag kano singil ng casa kung pa install ka ng dashcam?
    Sep 2005
    you can buy a YI dashcam for under 3T and install it yourself.. tatago mo lang wires..
    Jul 2013
    I know
    pero gusto ko sana sa fuse box galing yung power...
    I know
    pwede naman kung gusto mo, gamit ka lang ng fusible tap/link.
    Jul 2013
    I know
    I'll post mine pag-nagawa ko na.
    You just need a fuse tap (I bought 5pcs for 250 petot online) and couple of feet of wire.
    Instead of buying a hardwire power adapter, I'll just connect the existing power supply to the fuse tap (maybe solder for better connection).
    Youtube is my teacher for this.
    Jul 2013
    ^marunong naman ako gumawa...
    kaso kung 1.5k lang (as mentioned above), pwede na...
    Jan 2008
    I know
    yung cigarette lighter or accessory line ang best power source for dashcam..
    Jul 2014
    I know
    you can connect to fusebox using the supplied cigar charger then hide the cables.
    you need a soldering iron and red and black wires about 6inches long.
    open the cigar charger then locate the positive and negative terminals
    solder the red wire to positive and black to negative
    reassemble the cigar charger with the two wires extending out.
    in the fusebox, locate the cigar lighter fuse and tap the red wire.
    connect the black wire to any metal screw under the dash.
    use cable tie to tighten loose cable and find a hiding place under the dash.
    check everything works by switching your keys to ACC or ON.
    Mar 2018
    DDPai PRICELIST as of October 2018
    visit my page for more info Bry'z Gizmos - Accessories - Las Pinas | Facebook - 1 Reviews - 1,712 Photos
Blackbox DVR/Dashcam
