Anybody knows how to convert yung file na galing sa DP520? Di ma upload sa social media.. and ano gamit nyo pang edit. Ty!
Sent from my SM-N9208 using Tsikot Forums mobile app
It should be .MOV files, which is generally supported by Facebook or Youtube. Baka masyado malaki lang yung files (200+ MB) kaya nahihirapan yung site?
If you're on Windows you can download Avidemux or Windows Movie Maker. Both are free and both are very easy to use, especially if all you need is to cut the video and convert it to a smaller mp4 file. You can even add titles and scene transitions. Try to keep your files at less than 100MB para madali i-upload with less errors.
Bili ka na lang sa lazada. Pareho ba sya ng thread ng sa sjcam? If yes, bili ka lang ng car mount. 350 lang yun
Nuong una, I was thinking how to convert it to .mp4 from .AVI file na-record ng dash cam. Wala na ako PC or Laptop, I am just using this Android phone. Pero I was able to upload a 5 minute video clip, in Facebook and Youtube. Matagal nga lang talaga ma-upload lalo na sa Facebook, at kapag mahina o mabagal ang internet connection.
Sent from my Up Snap using Tapatalk
baka masyado malaki file size mo. you can edit your video with windows movie maker, then compress it using handbrake.
here's an updated handbrake tutorial; How to Make Your Video Upload Crystal Clear - 2 16 Edition - YouTube
^yup, okay yan bro. you can upload videos even * 4K with the updated tutorial.
Thanks sir. Every 3 minutes kasi cut ng vid ko. Nasa 170 mb na ata * 1080p. Will try your advice. Salamat!
If you're going to use Handbrake, then don't use Windows Movie Maker to edit the scenes! WMM maxes its outputs to 720p, and all of their settings are "lossy" so by the time you are transcoding with Handbrake, may konting degradation na ang source. Indeed, kung gagamit ka lang ng WMM, then use its built-in transcoding settings. I use the "Facebook" settings because it outputs clear video at 720p with negligible artifacts and a much lower filesize.
If you want to use Handbrake, then use Avidemux to edit the video and choose "copy" for both video and audio output, so that the file output will not be transcoded during editing.
Or you can forget Handbrake and use Avidemux directly to transcode the video after editing. Avidemux, like Handbrake, uses ffmpeg, and you can configure Avidemux to output similarly to Handbrake. Medyo matrabaho lang i-configure but it can be done.
Hi, question sa mga transcend users. Bought my DrivePro 520 few months ago (more or less 3 months), ngayon yung experience ko is naghahang sya randomly, medyo hassle kasi malaki posibility na mabangga ako tapos hindi pala nagrerecord yung dashcam ko. May naka experience na ba neto? And saan pwede ipadala for repairs? Bought my DP520 from PCWORX. thank you.
As dreamur said. Check and review your settings. And check your micro SD memory card if compatible to the device. Mostly they recommend Class 10 memory card. Ang default setting yata sa loop recording kadalasan sa mga dash cam ay 3mins.
Have you tried to reformat the micro SD card on the device since you first insert or installed in it?
Kung nagha-hang pa rin.
Have you tried resetting it? Or restore to system default setting? Then check or trial it out again kung mag-hang pa rin after resetting. Kung mag-hang pa rin palagi, bring it back sa store where you bought it for warranty service repairs.
