Page 66 of 176 FirstFirst ... 165662636465666768697076116166 ... LastLast
Results 1,301 to 1,320 of 3510
    Oct 2009
    #1301
    sa mga holiday shoppers jan. mukhang mas maraming na kayong mapipilian na pang dashcam that double also as an action cam.
    Sep 2012
    #1302
    Quote Originally Posted by wewoy_romero View Post
    hindi naman lahat ng tint. may mga specific lang. ang madalas na nababasa ko yung 3m BC (magic) tint. meron iba, nawawala signal sa gps, mobile or mga easypass. yung iba naman daw matagal lang mag-lock. and still meron naman iba na wala naman daw issue.
    sa akin never had problems sa 3m cs (color stable). dark wraparound + medium windshield. galing din ako sa solargard charcoal medum all-around. palagi ako naka-waze. wala naman problema.
    I had to compromise by doing this para lang gumana yung GPS.
    Pinabutasan ko ng kasing laki ng CD then pinalagyan na lqng ng Super Black tint ulit
    Sent via Tapatalk
    Quote Originally Posted by lakay77 View Post
    nagdadalawang isisp na tuloy ako sa pagpapalagay ng tint
    look at the specs of the tint, wag yung may mga metallic tint like 3m magic. metallic substance block gps signal
    #1304
    After 1 year of use, my SJ4000's battery gave up on me:
    The camera itself still works. Will connect it directly to AC power to still serve its function as a dashcam. Will also buy a new battery in case I wanna use it as an action cam, but won't put it in the camera anymore when I use it as a dashcam.
    I think it's really inevitable that the battery will bloat when exposed to direct sunlight in a hot cabin all day. Since the battery has bloated, I had to remove the front housing of the SJ4000 as well as the screws of the circuit board to be able to pry out the battery.
    On another note, does anyone have an idea how I can attach a dashcam onto my Mazda? This is how the rearview mirror and housing of the auto-light and rain sensor looks like:
    There are 2 main problems in that layout:
    1. The stalk of the rearview mirror is too short. I can't do what I did with my Toyota wherein I used a bike mount to latch it on the stalk, like this:
    2. The housing for the rain/light sensor is big enough to hold my suction cup, but it's a rough surface, so the suction cup cannot grip onto it. I've also tried using double sided tape as well as packaging tape, but both don't stick either.
    Since I don't wanna damage my tint by using a suction cup directly on the windshield, I'm still unable to mount a dashcam on my Mazda. I'd be grateful to hear any ideas. [emoji4]
    Jan 2011
    #1305
    ^What kind of double sided tape did you use? You can try using 3M VHB double sided tape like this:
    I've used this on the matte plastic of the City's console. Just make sure you clean the surface with alcohol before applying the tape.
    #1306
    Quote Originally Posted by cityfolk View Post
    Used 3M automotive tape (looks like that too), doesn't stick at all.
    Apr 2006
    #1307
    *jut703
    gumagana naman as dashcam even without battery no? pero yung settings ba nareretain kapag walang battery? i mean, yung date/time, exposure, plate number, etc?
    pareho tayo ng problem dun sa stalk ng rear view mirror. di ko rin magamit kahit anong mount kasi masyado maikli or nakabend yung stalk. kahit yung mga industrial tape ng 3m hindi mo rin madikit kapag rough surface yung pag-gamitin. you can smoothen it siguro using sandpaper. pero ako suction cup gamit ko, wala naman issue sa tint.
    *jodski
    halata ba na iba yung tint sa labas. no choice talaga no? unless whole windshield papalitan mo ng tint.
    Sep 2012
    #1308
    *jut703
    *jodski
    [emoji1] halatang halata sa labas bro hahaha. Parang magkakaroon ng black hole ang dating
    Pero it is a compromise na tinanggap ko na kasi mas gusto ko retain yung magic tint sa majority ng windshield.
    Sent via Tapatalk
    Apr 2006
    #1309
    na-research ko kasi dati yan nung nagpalit ako ng tint just lately. 3m magic provides the highest tser heat rejection sa 3m without costing too much and hindi yung clear series nila kasi kailangan ng mga pasahero ko ng privacy.
    marami nagsasabi na affected gps, mobile signal, rfid, etc nila. eh gamit na gamit ko waze kaya kailangan reliable gps ko.
    Apr 2006
    #1310
    sana pala pina-shape mo na parang katulad dun sa mga windshield ng ibang sasakyan wherein nakadikit sa windshield yung stalk ng rear view mirror nila. yung parang may dark portion sila na dotted.
    Sep 2012
    #1311
    Ayus lang yun bro hehehe... nag sigurista mode lang ako sa butas.
    Sent via Tapatalk
    Jun 2012
    #1312
    Now 13th month is just around the corner, I can confidently commit na to buy a replacement cam.
    But I'm still torn between G1W and SJCAM 4000.
    Jun 2009
    #1313
    gamitin mo yung pang helmet mount at idikit sa likod ng rear view mirror.
    #1314
    Quote Originally Posted by KERSMcRae View Post
    Rough surface. 3M adhesive doesn't stick at all. [emoji20]
    Apr 2006
    #1315
    yep also tried it before. pag naarawan na, mahuhulog. suggestion sa akin is to sand the back of the rear view mirror kung saan ididikit yung mount.kaya lang ayoko hehe
    Oct 2009
    #1316
    Quote Originally Posted by Roden Villegas View Post
    Both have the same video quality since both have the same exact hardware. The advantage of the sjcam is, it doubles as a action cam.
    #1317
    Saan po ulit may nabibilihan ng murang sjcam 4000? D ko po kc makita dito sa thread
    Jun 2012
    #1318
    Quote Originally Posted by battouter View Post
    SJCAM it is! Thanks papa!
    #1319
    Snipped
    bro jut ayaw mo pa fabricate nalang? Pakita mo nalang sa gagawa para madiskartehan. Creative naman mga yan :D
    Dec 2012
    #1320
    Transcend DrivePro 220
    https://www.youtube.com/watch?v=QkJ_clkGOZA
    Transcend Drivepro 200
    https://www.youtube.com/watch?v=iEW4mxG9Cn4
    although di pinas or tropical ang setting, kahit papaano may idea na tayo kung ano ang overall performance.
Blackbox DVR/Dashcam
