Page 44 of 176 FirstFirst ... 344041424344454647485494144 ... LastLast
Results 861 to 880 of 3510
    Aug 2006
    #861
    Hi Kimot,
    Ilang beses ng bumigay yung suction mount
    Buti na lang, naka tali sa rearview stalk yung usb cable kaya hindi bumabagsak yung DP220...
    I think standard yung saksakan nila like g1w dahil yung 2 suction mount ko for cell phone e puede rin sa dp220 ... But its bigger and bulkier than the dp220 suction mount.
    Hence, the search is on for g1w rearview stalk mount
    May 2010
    #862
    Quote Originally Posted by luis_ View Post
    Sir try adding 2 extenders para magkaron ka ng horizontal and vertical adjuster. Medyo bababa nga lang position ng camera pero pwede naman siguro iextend mo na lang paharap.
    Quote Originally Posted by wewoy_romero
    Quote Originally Posted by keto View Post
    Copied sir jut703's setup however the adapter that I have is not parallel to the mount when fully screwed on, anybody else encountered the same problem with their sj4000s? Di tuloy 180 degree yung scope ng cam. Maybe I have a faulty adapter?
    *keto
    it depends on how your rear view mirror is set up - specifically yung "stalk". look at my post on page 83 with pictures of the mounts that i have and the rear view mirror of my gen1 crv.
    di ko rin magamit yung dalawang mount na naka-attach sana sa rear view mirror because of the way the stalk is curved. maikakabit ko, pero hindi ko ma-aim ng matino yung sj4000.
    The stalk and the mount itself is ok, ang problema talaga is yung parang screw on type adapter or yung part that the screw is screwed (lol) into dun sa regular na case nung cam. Yung culprit ko talaga is the screw adapter, kasi whether you screw it into the bottom or the top of the case baliko siya. So much for quality control lol.
    I'll try different mounts this weekend when I route the cable under the A pillars. Aside from the problem with the screw type adapter, ok naman yung Sj4000 as a dashcam.
    I ordered this through geekbuying.com and cost me $85 plus shipping as it is coming from China. I will share a review and a video sample as soon as I receive it.
    Product Description
    Highlights178 degree super wide angle lens.2304*1296/30fps high definition resolution.Advanced H.264 video compression technology.2.7 inch high resolution LCD, can view while recording.Support HDMI high quality video transmission.G-Sensor to keep the record of sensor data at emergency cannot be coverLoop recording with seamless, does not leak second.Automatic circulating recording, it’s able to set the record time for each file.Watching video simultaneous while driving, supporting on-spot play back.Time & date display changed, there is no need to reset when re-starts.A key to lock functionMotion detection functionAutomatically turn on/off functionCan charge and transmission through USB.Equipped with special car fixed sucker, easy to fix and use.Maximum memory storage 32GB, or TF with more high capacity storage device.
    Apr 2011
    #864
    meron pala sa blade?
    Planning to get this too, my only concern is since you'll be leaving this mounted sa car, it might attract bad elements
    mabasag kotse ka at manakaw mismo yung cam, flashy kasi at mukhang pricey.
    Yep meron. 6k plus. Sa Lazada meron 5k lang pero stripped down version siya. When you check the 'what's in the box' section, nakalagay lang yung camera mismo saka yung suction mount. walang ibang peripherals. Yung fully loaded version nasa 5800. Not bad I guess. Maganda din naman review sa youtube nung camera na yun. Also I believe natatanggal naman yung camera.
    This is how the g1w mount looks like, let me know if somebody is interested for a group buy. ;)
    Attachment 27927
    Puwede ba na yung mount lang bilhin? If yes, count me in for the group buy.
    #866
    Feb 2007
    #867
    Yes sir pweding pwede.
    Aug 2006
    #868
    Magkano kaya pag group buy?
    May 2010
    #869
    Quote Originally Posted by n5110 View Post
    Got a gorillapod to mount my sj4000 on the rearview mirror stalk before I figured out that the screw on mount is adjustable. At least I can use it as a tripod lol
    Apr 2006
    #870
    ganyan din isa sa naisip ko na pag-mount pero hindi talaga pwede dahil sa rear view mirror ko. kahit ilang attachments pagsama-samahin ko, di talaga magfit.
    suction mount lang talaga pwede.
    Sep 2004
    #871
    Quote Originally Posted by macstar1 View Post
    I ended up buying Transcend DP220 at TCA.
    Ang kulit ng taga Blade pero di niya alam pinagsasabi nya.
    Less 5% sa TCA pag cash.
    So far OK naman ang performance.
    Problema lang e suction cup siya kaya weekly e ina ayos ko yung mount to make sure.
    But if you can get a g1w rearview mirror mount, mukhang compatible siya.
    confirmed ba na kasya sir? may nakita kasi ako nagbebenta sa fb e
    https://www.facebook.com/itemshop.ph?fref=ts
    Aug 2006
    #872
    Mukhang OK naman. Nagtanong ako kung paano um order
    Kasi yung luma kong CDRKing na mount, sakto sa DP220 ko e
    Di ko pa lang mai post ang pic, pero 2 arm kasi yung sa cdrking kaya nasa oagitan ang rearview mirror stalk. Para matangal man ang suction, di pa rin mala laglag ang dp220
    Aug 2006
    #873
    My DP220 via CDR Mount, rearview mirror stalk in between.
    Sep 2004
    #874
    Tnx bro order na ako hehe
    #875
    Gandang umaga, tanong lang po. Baka po meron po kayo alam kung saan may nabibilihan ng fuse tap kit for mini fuses. Salamat po
    #876
    Bro, here's some night footage of the SJ4000:
    NLEX SCTEX Ecorun - YouTube
    Ecorun (as evidenced by being overtaken by all cars hehe) from Dinalupihan to Balintawak. I started driving at dusk so you'd see the transition from day to night. Clear tint na ko niyan, but hindi talaga masyadong maganda video quality if walang road lighting.
    Bro you must take a look at SJ 5000+
    SJCAM SJ4000 vs SJ5000 - What is the difference? | SjCamGuides
    Jul 2015
    #877
    Do you have pictures from the front? Where does the cable go? Directly to the battery or the lighter socket? Thx
    #878
    Thanks, I definitely plan to upgrade to an SJ5000+, but only when my SJ4000 breaks down. It's been half a year of being exposed to extreme heat almost daily but it's still working as well as it did in day 1.
    I would really advise you to learn how to quote posts, so that the person you're requesting pics from would know that it's him you're referring to.
    My order from Lazada has finally arrived. Will see if this works better than the one I ordered straight from China where the manual is practically cut and pasted from a chinese-english translator site.
    #880
    that's nice bro. yung akin pamatay sunog lang--
Blackbox DVR/Dashcam
