SJ4000
Malapit na ako makatawid (1-way; road under construction), salubungin ba naman ako ng kumag na trak (pick up) driver! Tumama pa sa side mirror ko yung 2nd trak!
SJ4000
Guys, any review sa G1W dashcam na binebenta sa kimstore? May nakabili na ba? How's video quality?
Hi everyone! Has anybody successfully used a rear view mirror clamp mount with a DP200? If yes, pa-share naman kung saan nyo nabili yung mount and what kind of modifications you had to make if any. Thanks in advance!
Sample day time footage DP220 behind 3M Magic Tint
https://youtu.be/GNTOii9iO_k
Sent via Tapatalk
Around 6:45 AM today...
Will post night time shots later.
One thing that I'm trying to figure out is the reason why I can't get a GPS fix.
Probably that its either because of the tint or because it was cloudy and I'm hoping it's just the latter [emoji28] [emoji41]
Sent via Tapatalk
Here's mine. Binabaan ko yung video quality para mabilis mai-upload. Kung mapapansin mo kita ng konti yung dash at bonnet/hood ng car ko. Medyo itutungo ko pa nga sya ng konti eh.
https://youtu.be/xL_4QDN1ico
Dampot lang ng mga tips sa web.
When any dashboard camera is installed its location should have these attributes:
The dash cam should be faced slightly down to limit glare and improve a cameras white balance.
Ensure the bonnet is captured in the footage from the dashboard camera.
Everyone loves the sky but, unless you're trying to capture the next meteorite landing, you should limit the amount of sky you capture as you drive. The more sky you have the more sunlight you get which results in more glare, reducing the quality of the video. The camera will also try to compensate for the brightness of the sky, darkening the video, which can make the detail on other vehicles harder to make out. It doesn't matter if you record more of the car dashboard - as long as you capture the road ahead.
