Page 80 of 351 FirstFirst ... 307076777879808182838490130180 ... LastLast
Results 791 to 800 of 3510
    Jun 2006
    #791
    Hi, would like to ask for opinion on which is a better buy, SJ4000 or G1W-C? This will be mainly use for dash-cam. Would prefer a G1W-CB but can't seem to find it locally.
    Jun 2009
    #792
    Quote Originally Posted by Sebastian Bach View Post
    Need help, anyone here knows where to buy 4 to 5meters of micro usb cable for SJ4000? papagapangin ko sana sa pillars para hindi sagabal sa view. I've tried several cdrking branches kaso wala. kahit sa tyangge2 sa malls wala din.
    nakabili ako ng 3m sa lazada, charger cable pang smartphone. di ko pa nabuksan para macompare ang wire size (awg).
    No need for 4m cables. I used the stock cable that came with my SJ4000's car charger (about 1.5-2m long), and it was long enough to hide in the headliner and A-pillars, and connect directly to the ignition so it won't use up your 12V socket anymore.
    di ba delikado pag mainitan ang wire (heat conduction) pag nasa headliner? Balak ko rin ilagay yung nabili kung cable, lalo na pag summer?
    Jun 2015
    #793
    Hi guys,
    For those looking for the G1X dashcam series, we are selling the G1W-C from Blueskysea and it already includes the rear view mirror mount for 3495 only. Capacitor series tend to last longer due to higher heat resistance. Our facebook page is ND AutoMart - Car Parts & Accessories, Wholesale & Supply Store | Facebook for those who might be interested. Also includes free shipping =)
    Thanks!
    Hi guys,
    For those looking for the G1X dashcam series, we are selling the G1W-C from Blueskysea and it already includes the rear view mirror mount for 3495 only. Capacitor series tend to last longer due to higher heat resistance. Our facebook page is www.facebook.com/ndautomart for those who might be interested. Also includes free shipping =)
    Thanks!
    Apr 2006
    #794
    Quote Originally Posted by tevilo View Post
    Friendly advice for those who got the G1W/G1WH dashcams, try replacing your current suction cup with this rear mirror mount. More sturdy and won't fall-off kapag tirik ang kainitan ng araw plus no damage pa sa tint kung meron man. Though hindi sya nakatago sa likod ng rear mirror but stays exactly right below it. That for less than $3 sa eBay.
    bought this kind of mount for my sj4000. mukhang hindi pwede sa crv2000 na model. pati yung included na mount similar sa post ni jut hindi rin pwede.
    haaay looks like i'm stuck with the suction cup.
    #795
    Quote Originally Posted by KERSMcRae View Post
    Heat doesn't really penetrate the car's headliner (otherwise, it'd be very hot inside your car the moment you expose it to the sun). Hindi siya parang yero na sobrang init.
    Also, the cable still has its housing, it's not exposed. The housing won't melt unless you subject it to really really hot temps like a soldering gun. From the inside out, it also won't heat up unless the + and - wires are grounded, but since I didn't touch any of that, it's safe.
    Worst case scenario is an oversupply of voltage from the AC power, but that's why I had a fuse installed for additional safety.
    #796
    Bro jut, favor naman. Baka pwede ka mag upload ng video ng night time driving via dark road
    Ito kasi pulot ko sa tipidpc, medyo ok eh.
    Anything similar or better would be OK with me
    Mivue500 Dashboard Cam Nightdrive Sample - YouTube
    Post no thakker from tpc
    TipidPC.com | TPC Hatchback Thread
    Same kasi sila halos ng price ng sj4000
    Aug 2006
    #797
    Anyone here using Trancend DrivePro 220.
    I ended up getting DP220 for Wifey's Monty.
    But for now, I'm doing "BETA Test" on my car habang nasa casa pa ang oto nya for PMS.
    Ok naman ang dp220 when using the packaged car charger.
    Ang laki nga lang ng plug nya kaya hassle.
    However, may nakaayos nang USB extension cable sa oto ko since I'm currently using Note3 with DailyRoads Voyager as dashboard cam for my car (tangal kabit nga lang). The usb cable is plugged to my gopro car charger with 1ampere and 2ampere output.
    Problem is, when I try plugging the dp220, unstable si dp220 at panay ang reboot, regardless if I use 1ampere or 2ampere socket. Kahit yung ibang usb car charger ko e palpak pa rin.
    May nakaranas na ba ng ganitong issue sa dashcam nyo?
    A friend mentioned I may have to use a simple charging cable rather than a data cable, problem is... Its not that easy to find a charging cable from pc shops.
    Jan 2012
    #798
    Drivepro 200 user here
    so far di naman naeexperience yung sinabi mong issue whether i use the 1amp or 2 amp slot. data cable rin lang gamit ko since i'm using capdase car voltage monitor as the power supply.
    try mo kaya gumamit ng ibagn USB cable or upgrade mo yung fw ng drivepro.
    Aug 2006
    #799
    Hi Kimot,
    1.07 na yung FW w/c is the latest in their support site
    You have a wicked car charger though
    Hence, Im guessing it could be the charger, or the USB cable, or both.
    So for my Science experiment case 1, i tried using a powerbank and the same USB cable MINUS the extension - EPIC FAIL - problem persist
    For case 2, I replaced the USB cable with my 10year old motorola Dual-fuse USB cable that goes with my ht820 headset (which still works brw, despite the pads and paint job issue)
    This time, DP220 did worked properly ... So looks like some USB cable really are better than others.
    Im still saving up for my own car's "vkool windshield tint + osram NB + dashcam" project though ... So I can't afford a cool but expensive charger like yours ... So for case #3, I'll try the USB cable with my current charger tomorrow
    Thanks!
    Feb 2007
    #800
    Quote Originally Posted by wewoy_romero View Post
    My rearview mount for sjcam.
Blackbox DVR/Dashcam
