Results 141 to 150 of 259
- Jul 2012
- 274
May 12th, 2014 04:21 PM #141Sir CVT try turning on the Garmin GPS before connecting it to the computer via USB cable. I discovered this out of frustration as I could not figure out why my PC can't detect my Garmin GPS before. Normally, most usb devices are and should be detected by the computer whether it is turned on or off.
- Jul 2012
- 274
May 12th, 2014 04:26 PM #142I always use my Garmin GPS. Helped me a number of times when I got lost on the side streets here in Metro Manila. I also use Waze, pero usually before driving just to check for traffic.
- Jul 2005
- 430
May 26th, 2014 09:47 PM #143I have Waze, Google Maps, and Navigator in my phone pero I prefer my car's built-in GPS (AVT).. Hassle kasi dati nung phone pa gamit ko na pag naliligaw ako I had to pull out my phone, turn on the gps, turn on the app, key in my destination, plug sa charger, ikabit sa car mount and wait for the phone mag-lock sa satellites before I can go. Tapos biglang tatawag or magtetext.
Whereas sa built-in, I only need to press a few keys and pwede na sumibad in a few seconds since mabilis mag-lock sa satellite.
Only disadvantage is kailangan pa maghintay ng updates from AVT.
May 26th, 2014 10:21 PM #144
I still prefer the GPS installed in vehicles,
kasi pag sa smartphone tagal maghanap yung gps lalo napag sa
province hirap talaga kailangan ng wifi or dapat postpaid smartphone mo
- Jun 2011
- 204
May 26th, 2014 10:50 PM #145I got no problem using waze with my ipad mini r with globe plan, compare sa smartphone ang bilis ma drain battery, sa ipad mini ang tagal. Kahit 4 hours ako nasa kalsada without charging go pa rin si ipad mini ko. Pero of course i also want to try yung built in baka nga less hassle. Problem ko lang is HU ko has this gps card slot, but i dont have the card when i bought this car. Sabi nila gagastos ako ng mga 6k just to have this micro sd card para mapagana ko yung gps sa HU ko. Nagdadalawang isip pa rin ko, effective naman sa akin si waze pa.
Posted via Tsikot Mobile App
May 27th, 2014 02:35 PM #146
i use BBT, better than any gps or smartphone.
Baba Bintana Tanong
anyway i have handheld gps and phone's map if BBT does not work (no signal)Last edited by miLes; May 27th, 2014 at 02:39 PM.
May 27th, 2014 11:30 PM #147
I also use my phone, I usually use Google Maps as its less data intensive compared to waze
But my issue is that I loose GPS signal in even in the smallest overpass and it takes an eternity to get a lock again. It becomes kinda useless in Edsa because it always looses signal when Im under the MRT or an underpass.
What inexpensive standalone GPS do you recommend? I have looked around and the cheapest ones I can find (Garmin) are around 7k and that costs as much as a basic android phone with GPS already.
Another question. Who has tried a GPS re-radiating antenna? I found one in sulit for P2300 and it apparently improves the signal inside the car
- Sep 2013
- 893
May 27th, 2014 11:47 PM #148
- Jun 2011
- 204
- Sep 2013
- 893
May 28th, 2014 08:57 PM #150
Jay Leno Drives the 2024 Toyota GR Corolla — Rally Rocket for the Streets! | Jay Leno's Garage Jay...
2023 Toyota GR Corolla Hatchback
