Page 1 of 4 1234 LastLast
Results 1 to 20 of 73
    May 2012
    I've been searching the forum for the said topic but unfortunately sumakit yung mga mata ko.
    Guys, where can i buy LED bulbs for the instrument cluster? I was planning kasi to upgrade para mas malinaw and better to read at night since medyo malabo na ang mga mata ko. Thanks in advance..
    My led conversion is somewhere in their album
    https://www.facebook.com/media/set/?...8276590&type=3
    These guys did the conversion: https://www.facebook.com/pages/Jemso...8276590?ref=hl
    well, even shoemart has some LED bulbs corresponding to the common bulbs for peanut bulbs, cylindrical dome lights, and park lights.
    but i haven't yet seen smaller versions for the dashboard...
    btw, is it possible, your instrument cluster is dark because your light source is already too dirty? in this case, a simple cleaning with moist rag might be all you need.
    and these bulbs do not significantly weaken their light output with age. but napupundi sila.. two bulbs at mapundi ang isa, equals half the light output.
    and they do get covered with a heavy layer of dust. you kinow, dust under the dash just goes around and around in there..
    May 2012
    Pinalinis ko na. Yellow kasi yung color nya and masakit sa mata at night. Wanted to change it to white or blue but kailangan led para added modification na din.
    May 2012
    Pwede bang iDIY yung LED conversion? I'm from mindanao kasi sir and di ko alam kung saan bibili ng bulbs na LED..
    Pwede po diy. Just take out your gauge bulbs and go to the car accessory shop in your area. Most of the time, it just uses the same bulbs as the license plate lamps, see the fb album for reference. You need ones with both side firing and forward firing leds
    May 2012
    I still don't get it..
    Sa pictures kasi they've use 2 kinds of bulbs. Do i need a soldering gun and make my own led but using the old base or there is a readily available bulb na plug and play. Iba kasi yung led for parking lights, parang masyadong malaki siya..
    May 2010
    Mas relaxing sa mata ang green
    Plug and play lang po. Yung sumobra nilipat ko sa parking lights at license plate ko. Yun pong haba ang naiiba. Kasi kulang sa clearance yung ibang gauge kaya yun shorter ang ginagamit.
    Sep 2013
    Quote Originally Posted by SiRbossR View Post
    how to achieve this if you're already using aftermarket LED bulbs? i used the ones with 5-LEDs a piece. nagsawa na ko sa white, back to green sana. hehe
    May 2012
    Ano yung name ng bulb na dapat kong bilhin? Or just bring a sample for reference?
    Jun 2010
    Quote Originally Posted by Alfrance05 View Post
    T5 or T10 LED bulb , dalhin mo na lang sample para sur3
    May 2012
    Quote Originally Posted by raycon_24 View Post
    Thanks!! Hope smooth sailing yung DIY ko..
    Mar 2012
    ito po try nyo high powerled ---> https://www.facebook.com/highpower.led.7?fref=ts
    May 2012
    Quote Originally Posted by calix0305 View Post
    Content not found sir..
    Apr 2014
    Mga boss tanong lang. Not sure if this has been mentioned earlier. Plano ko sana palitan ung gauge lights ng '93 corolla XE ko currently 12V 3W sya. Can anyone can suggest a higher light output pero pasok pa din sa load? Hindi ko na kasi halos makita sa gabi ung speedometer ko. Not considering indiglo for now. Salamat po.
    Posted via Tsikot Mobile App
    Considering the age ng car, kung hindi ka pa nagpapalit ng bulbs sa instrument panel malamang worn out na mga filament ng bulbs.
    Pwede mong palitan ng normal T10 siguradong liliwanag na yan. Pag binuksan mo, makikita mo na maiitim na yung glass ng bulbs.
    Apr 2010
    Quote Originally Posted by tevilo View Post
    Ganito pinalit ko sa akin para all around ang buga. Pag one side lang may hotspot kasi sa dash.
    Amber para match sa stock color. Sakto lang yung brightness, ayoko kasi ng maliwanag masyado, nakakadistract sa gabi.
    Tanggalin mo rin yung 'globe' na nakapasok sa tachometer - eto kasi yung naglilimit ng brightness. Sorry wala akong pic neto, pero it looks like a half sphere made of plastic. Makikita mo naman yan when you insert your bulbs.
    Sep 2012
    ^ saan mo nabili yan bro and how much isa ?
    Thanks
    Sent from my Windows Phone 8 using Tapatalk
    Quote Originally Posted by jodski View Post
    Thanks
    Those LEDs can be bought at Blade stores, Concorde, Handyman/Ace Automotive Area, car accessory shops, Sulit/Ebay for online shopping... Price range usually 100-150pesos and up.
LED BULB for instrument panel
