Results 1 to 10 of 73
January 5th, 2014 12:37 AM #1
I've been searching the forum for the said topic but unfortunately sumakit yung mga mata ko.
Guys, where can i buy LED bulbs for the instrument cluster? I was planning kasi to upgrade para mas malinaw and better to read at night since medyo malabo na ang mga mata ko. Thanks in advance..
January 5th, 2014 12:41 AM #2
My led conversion is somewhere in their album
https://www.facebook.com/media/set/?...8276590&type=3
These guys did the conversion: https://www.facebook.com/pages/Jemso...8276590?ref=hl
- 52,842
January 5th, 2014 12:47 AM #3well, even shoemart has some LED bulbs corresponding to the common bulbs for peanut bulbs, cylindrical dome lights, and park lights.
but i haven't yet seen smaller versions for the dashboard...
btw, is it possible, your instrument cluster is dark because your light source is already too dirty? in this case, a simple cleaning with moist rag might be all you need.
and these bulbs do not significantly weaken their light output with age. but napupundi sila.. two bulbs at mapundi ang isa, equals half the light output.
and they do get covered with a heavy layer of dust. you kinow, dust under the dash just goes around and around in there..Last edited by dr. d; January 5th, 2014 at 12:49 AM.
January 5th, 2014 02:18 AM #4
January 5th, 2014 02:24 AM #5
January 5th, 2014 02:50 AM #6
Pwede po diy. Just take out your gauge bulbs and go to the car accessory shop in your area. Most of the time, it just uses the same bulbs as the license plate lamps, see the fb album for reference. You need ones with both side firing and forward firing leds
January 5th, 2014 10:38 AM #7
January 5th, 2014 03:04 PM #9
Plug and play lang po. Yung sumobra nilipat ko sa parking lights at license plate ko. Yun pong haba ang naiiba. Kasi kulang sa clearance yung ibang gauge kaya yun shorter ang ginagamit.
- Sep 2013
- 505
January 5th, 2014 08:31 PM #10
Agreed on the points raised. People buying an Innova do so because it's a workhorse. All of the...
