Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Aug 2012
    How bright are your headlights?
    Katuwaan lang. Since most smartphones now have built-in ambient light sensor. (Refer to your phone user manual where it is located.)
    1. Install MobiLux app in your Android phone and run it. Set offset to 0.50.
    2. At night time, turn on low beam. Put light sensor 12 inches away from low beam. What is the lux level?
    3. At night time, turn on high beam. Put light sensor 12 inches away from high beam. What is the lux level?
    4. Post the results as well as your headlight setup.
    Example only (Not actual data):
    1. Low beam: Reflector + Halogen (Osram Standard) = 1571.00 lux
    2. High beam: Projector + HID (Osram Standard) = 3031.50 lux
    *1 lux = 1 lumen per square meter
    Again, katuwaan lang po ito. Thanks sa mag-join.
    Sent from my D5833 using Tapatalk
    Jan 2009
    A word to the wise... Measurements might be inconsistent and inconclusive as these ambient light sensors aren't calibrated. Different phones, different brands of sensors, different optics, different 'bins', quality, etc. Besides, they needn't have to be accurate to function satisfactorily on a smartphone.
    Aug 2012
    As stated, katuwaan lang ito bro. Not professional measurement. We are just using smartphones here.
    Pwede ba ang sagot na "stock"?😉
    basag trip si oj88 ^_^
    pag palit ko headlight bro red, testing ko yan
    Jan 2009
    Basag trip? This is not a matter of taste or personal preference. If yellow is your favorite color, I can't tell you or force you to think that it's not just because my personal favorite is blue. But this is science. I don't see the fun in taking unreliable and unverifiable measurements.
    It's like the cliche, "How long is a piece of string?"
    But go ahead if you want to brag about lux and lumens. I'm not stopping you.
    Aug 2012
    Measure mo na kahit stock bulbs muna.
    You can also use the app to compare other bulbs. Example, reverse light from stock to LED; map light from stock to LED, etc.
    Aug 2012
    Yes, you can measure stock bulbs.
    Dec 2008
    Why not measure from the hotspot on the ground? That'd be a better measure, though it does not factor in the beam pattern and its uniformity.
    Sent from my SM-C7000 using Tapatalk
    Aug 2012
    Quote Originally Posted by stagea View Post
    Katuwaan lang kasi bro. So easiest way is just 12" away from headlight. We are all familiar with 1 ruler length from school.
