Results 11 to 13 of 13
January 20th, 2011 08:48 PM #11
HID's on halogen reflector - bad output
Superwhites - been there done that. 2 weeks lang, binenta ko na yung akin. Output sucks, bigtime.
Philips Xtreme power - stock-ish color but intense output. Maganda visibility sa ulan since it's halogen. Partner it with euroline/polarg/solarzen yellow bulbs for fogs.
Osram Nightbreakers - whitish output. weaker in rain. light is intense in dry pavements though.
January 21st, 2011 01:40 AM #12
for good visibility i'd stick with stock color ranging from 4500k to 5500k on halogen then if you want you can increase the wattage a bit 90/100w for h4 yan gamit ko sa lahat ng cars ko before i switch to hid. if you prefer halogen using this setup will give you better vision even when its raining. before i use flosser brand its just cheap , made in germany cost around 400 to 500 a pair.
then for the fogs yes you can use golden yellow bulbs. for fogs i would suggest that you get any brand whose bulb glass color is a bit of the rainbow still emit yellow color. rather than opting to get bulbs with pure yellow or dark yellow color glass as it filters the lumens coming out of it, the color will be good and pleasing but visibility wise its not good. when you look on the road and the road is wet it gives you less visibility than yellow emitting bulbs whose glass color is rainbow.
- Dec 2010
- 89
well, i have never met a victim admitting they maltreated their trans box...
The Toyota Fortuner has landed (fortuner pics at...
