Results 1 to 20 of 33
    Jun 2009
    here is my headlight
    newbie lang po.. sorry.. kaya i would just like to ask.. kasi yung camry (second gen) ko.. nakastock HID sha.. so pag ino- on ko yung Headlight ko.. yung HID yung LOW ko.. so sa picture yung naka GREEN circle lang ang umiilaw.. then pag HIGH naman yung nakacircle na RED (halogen) and GREEN (HID) yung umiilaw.. so question is.. pag bumili ba ko ng bagong HID.. kaylangan 2 pairs?? kasi gusto ko din ipa HID na yung HIGH beam ko.. or pwede na yung binebentang HI/LOW na HID?? correct me if im wrong.. pero ang plan ko kasi is HI/LOW ko sana is naka HID.. which means yung nakacircle ng RED at GREEN is magiging HID na.. panu kaya diskarte dyan mga sir? naguguluhan ako kung kaylangan ba 2 pair ang bilhin ko o yung isang pair lang na HI/LOW...
    AT.. if ever ba yung lumang HID na nakainstall now sa projector HL ko.. pwede ko ba ikabit sa FOG lights ko yun?? para ndi naman masayang? hehe
    TIA..
    hinde ata advisable sa HID yung pa flash flash lang. hintay tayo ng confirmation.
    yung mga naka HID na HI/LOW, alam ko isang bulb lang yon na may mechanical object na gumagalaw pag nag hi beam ka.
    tama ba? hihihi. nagmamagaling lang.
    robot.sonic
    I believe that your low beam has H3 bulbs, while your hi-beam is an H4 or H7 type. Dalawang separate HID kung sakasakali ang bibilhin mo pre.
    Jul 2004
    Quote Originally Posted by mazingerZ View Post
    His low beam bulbs are definitely not H3. Most probably it's D2S or other HID projector specific bulb. High beam is most probably 9005, H1 or other bulbs commonly used in high beams.
    All he needs to buy is one set of HID to replace the Halogen high beam. Then all is set na. High and low beam are all HID na.
    Hopefully, this guy does use his HID responsibly. Badtrip yun mga nagpapa HID sa highbeam din masyado nakakasilaw
    Jun 2009
    madaming salamat sa mga nagclear ng question ko.. dont worry sir im a responsible HID user naman.. super baba nga ng tutok ng HID ko.. kaya pag bumabyahe ako sa probinsya.. nahihirapan ako dahil bitin yung buga ng HIGH BEAM ko.. kaya gusto ko din sana iba HID.. para pogi points na.. mas malakas pa ang buga.. mas safe pa.. hehe
    Jul 2004
    Quote Originally Posted by majinbu View Post
    Actually, you don't need to adjust your headlights if all you are going to change are the high beams. Your car came stock with HID projectors naman and these are aimed properly so hindi ito nakakasilaw. Mkakasilaw ka lang if you use your Highbeams unnecessarily. So what you should do, aim your low beam properly first to factory specs then proceed with the installation of HID high beam.
    Usually new Japanese cars use D2S bulbs for the OEM Equipped HID. Projector type or Reflector Type.
    Then they use HB3 for the high beam.
    Ganyan sa CR-V ko.
    Sa Corolla Altis 2.0V.
    Sa Civic 2.0S / 2.0S-L.
    thanks for the tips mga sir.. actually napapaisip na nga ako ngayon. hehe looking at the fogs nga.. para nalang sha display light.. walang kabuga buga.. kaya naisipan ko ipaHID.. baka sakaling maging useful. pero what if hindi padin maganda ang buga. sayang lang ang HID.. hehe owell.. cguro papakabitan ko muna ng magandang brand na all weather bulb.. i'll see from there. =)
    anu ba bagay na kulay ng park light para sa camry? with that set up ng light? parang gusto ko blue led.. kaso parang baduy.. haha what do you think?
    Alam mo kung bakit?
    Hindi sa harapan ang buga ng fogs. Usually sa side. Pure yellow halogen bulbs lang katapat nyan.
    Tip ko lang, gawin mo din pure yellow yung high beam tapos maghanap ka ng yellow or amber (orange) na park light.
    Ganda nyan. Dapat decent looks. Camry pa naman yan, 3.0V V6 ba?
    Pwede rin 'to
    Jun 2009
    Ganyan sa CR-V ko.
    Alam mo kung bakit?
    yun nga sir.. sa side po yung buga niya. tapos super walang kwenta. haha as in line lang na manipis.. thats it. kaya nakakadisapoint, kasi may nakikita ako na ibang kotche na yung fogs nila though hindi nakakasilaw pag kasalubong mo pero super ganda ng buga. anyways, its a camry 2.4 sir, may nagsasabi nga i-JDM looks ko daw.. kaso hindi ko din naman alam anu yung looks na yun.. haha
    actually yung picture na sinend mo sir is yung target ko na looks.. haha simple but elegant..
    JDM
    Euro
    IMHO mas maganda Euro..
    Jul 2004
    TIA..
    a.) HIDs on your highbeam isn't really recommended as HIDs are not meant to be flashed(sudden on/off). Kaya naman but I think mas mabilis masisira
    b.) Should you decide to proceed with what you want, FYI, your High Beam is a separate bulb by itself(as you pointed it out). So you only need to buy one set of HID. Your low beam will be left as is. And what you will be getting is a single beam HID which will be installed on your high beam. Not High Low HID(hi/lo HIDs are for cars with one pair of bulbs only). Gets?
    c.) The bulb of your low beam and foglamp is different. So no, you can't transfer your HID low beam to the foglamp.
    Jun 2009
    Quote Originally Posted by glntVR View Post
    thanks sir.. BTW.. so yung low beam ko.. hindi ko na sha kaylangan bilhan ng bagong "HI/LOW" na HID right? or pwede din? para mangyayare pag nag HIGH BEAM ako.. solid ang labas?? possible ba yun?
    Jul 2004
    Nope. No need to touch anything sa low beam. And the only thing you can do with low beam is change the bulb to a bluish or yellowish bulb. that's it.
    Another option would be to retrofit a bi-xenon projector.
    Jun 2009
    ahh ok ok.. thanks sir..
    nasilip ko na yung bulb type ko..
    lowbeam = D2S/H7 (same lang ba to?? hehe)
    hign beam = HB3
    fogs = HB4
    ang HB3 ba at H3 or HB4 at H4 ba ay iisa lang?? any difference?
    TIA
    Jul 2004
    hign beam = HB3
    fogs = HB4
    TIA
    Low beam is D2S. D2S and H7 are different.
    High beam - HB3 a.k.a. 9005
    fogs - HB4 a.k.a. 9006
    hb3 is different from h3, hb4 and h4 are different.
    So this is what you need to buy, HB3 HID kit for your high beam. If gusto mo pati fog lamps buy an HB4 HID kit as well.
    TIA..
    hmmmmmm. eto payo ko lang
    yung low beam mo gusto mo palitan ng hid? ibang kulay ba prefer mo kasi if galing casa yan 35w 4300k yan for sure. not sure if d2s or d4s gamit nyan kung di ka magpapalit ng ibang kulay like 6000k or 8000k wag mo na palitan.
    now for the high beam yeah walang prob if papa hid mo pwede ka pumili between 35w or 50w.
    yung iba sinasabi na masisira ang hid sa pag flash flash mo well totoo iiksi life. pero even hindi mo pa hid ang high beam mo pag flash ka ng flash yung low beam mo naka hid, sasabay sa high beam yan if you dont believe me try mo:0 pa flash mo sa friend mo headlight mo sabay ang low at high tignan mo sa harap. so iwasan mo nalang or hold mo nalang longer pag na flash mo hold mo nalang. maski di hid ang high beam pag flash mo ng iflash masisira din low beam mo
    so pwede ka mag hid sa high beam total ang high beam talaga ke hid o hindi talagang nakakasilaw. dahil ang buga nyan palayo talaga.
    now kung gusto mo ilipat ang hid sa headlight low beam sa fogs. pwede pero given na d2s ang hid mo sa headlight papalit ka lang ng bulb. since iba ang bulb ng fogs forsure sa headlight low beam.
    kung may questions ka pa pwede mo ko tawagan 2114923 pakilala ka lang thanks wireless landline ko yan.
    Kumikitang kabuhayan ah... :um:
clarification regarding my headlights
