Page 1 of 3 123 LastLast
Results 1 to 20 of 41
    Aug 2011
    anyone knows where to buy those blinking brake lights?
    Feb 2007
    I have the strobe controllers sir.
    Text me: 09192529579
    Jun 2010
    yun ba yung triangle shape ala f1 brake lights? sa mga motorcycle shops marami
    Feb 2007
    Strobe Controller can be used with your stock third brake lights
    Aug 2011
    what i mean is yung brake lights talaga. may nakikita kasi ako ibang sasakyan ung park lights naka steady pero pag brake ng bi blink o ng flash ung ilaw.
    Yung F1-style LED brake lights parang sobrang gasgas na. Kanina lang ultimo trak ng basura meron.
    Feb 2007
    Quote Originally Posted by jncp9886 View Post
    Correct. If gusto nyo mag-blink yung brake lights nyo pati 3rd brake light, you need 3pcs strobe controller.
    Feb 2009
    hindi ba masyadong yudab ito?
    Feb 2007
    Pag stock lights, no.
    At least for me.
    Mas baduy kung extra lights.
    Siguro kung third brake lights lang lalo na kung LED na yun stock. Mga 3-4 blinks before mag steady pwede na.. The purpose is to catch the attention of the cars at your back naman e, for me medyo added safety naman.
    Sent from my LT26i using Tapatalk 2
    Feb 2009
    for the sake of discussion, flashing blue lights on a vehicle means police trying to pull you over or trying to tell you make way
    flashing white light means an ambulance on an emergency and sometimes with flashing red
    flashing yellow means slow moving equipment and a road hazard.
    check with local regulations and the department of motor vehicles first.
    on cars with seven wire system, the brake light works as signal lights, so, if you make them blink, it will be hazard lights since the seven wire system does not have dedicated amber turn signal/hazard lights
    Feb 2007
    Strobes fast > blinks 4x > steady.
    This is how the controller works.
    More of a safety add on, and is also legal.
    Jan 2009
    I did mine DIY.
    I bought the controller from eBay way back 2010. I then replaced the stock bulb-type 3rd-brake lamp assembly with an LED-type model from the USDM Civic Hybrid I bought from a forum member.
    I've programmed it to blink a few times at medium speed then go steady. It strikes a balance between being noticeable, yet isn't annoying to drivers behind.
    The result:
    The video doesn't do much justice but it's all I have.
    Nov 2011
    ^nice. kapag ordinary bulb sir hindi pwede or hindi tatagal unlike leds?
    Jan 2009
    Quote Originally Posted by silver V View Post
    Pwede naman. No issue sa lifespan. The only problem is, mabagal response time ng filament bulb compared to LED. I originally tried blinking the stock 3rd brake lamp but I didn't like it. That's why I sought out to get the OEM LED 3rd brake lamp assembly. Suffice to say, mas effective ang LED sa strobe effect.
    This is the video of the OLD setup using the stock bulb-type 3rd brake lamp.
    First Try: 3rd Brake Light Flasher (non-LED) - YouTube
    A note of caution to the DIYers: DO NOT blink all the brake lights. It looks stupid, is annoying, and can be illegal. Keep it simple and OEM as much as you can.
    Jul 2006
    Blinking brake lights!
    In line with the Christmas cheer eh?
    Feb 2007
    Got a couple of modules left! :P
    :thumbsup:
    Jan 2014
    I have seen a Blinking brake light in a taxi last night
    And it is annoying and irritating gabi pa naman iyon
    Jul 2011
    Anything that adds visibility ng kotse mo to other motorists sa kalsada is surely a benefit,
    who doesn't want added safety feature sa kotse.
    pero as the previous poster said, and for me, i think its yudab.
    just like those underglow neon lights, i saw a car with underglow neons the other night
    and aninag ko pa sya kahit malayo layo na sya. added visibility yes, but not of my taste.
    i just make sure all my lights (park, head, tail, signal) works properly.
    Jul 2013
    The problem with blinking taillights – Editor Speaks | Autodeal
    When it comes to blinking brake lights there are legal issues that surround it. The first is from the Land Transportation and Traffic Code, and the second comes from Presidential Decree Number 96. The Land Transportation and Traffic Code states that “every motor vehicle shall be equipped with at least one lamp which shall throw a sustained bright red light visible under all conditions, even under bright sunlight, when the brakes are applied.'' While Presidential Decree Number 96 has this to say: “That it shall be unlawful for the owner or possessor of any motor vehicle to use or attach to his vehicle any siren, bell, horn, whistle, or other similar gadgets that produce exceptionally loud or startling sounds, including dome lights, blinkers, and other similar signaling or flashing devices.” The strobing brake lights in question can technically be considered as blinkers since there is no distinction between those used by emergency vehicles and private vehicles as brake lights; it’s all up to interpretation. That’s two counts against these constantly blinking brake lights in the eyes of the law.
