Just want to share with you guys projects I've done in recent past:
FXR on FD
Quad setup on FD
Quad set up, TL ZKWR + FXR! with custom LED sidemarkers
FXR on FD
Quad setup on FD
'04 Starex
EG FX35 + fogs
'09 Subaru Forester, G35 outer + TSX inner! All OEM!
Honda Jazz '09, FXR
JDM Pajero
Retrofitting basically allows you to maximize HID technology without safety issues with other motorists. This is the right way to use HID.
Questions?
Ask away!
Last edited by ecg_6153; February 12th, 2010 at 09:39 AM. Reason: capital letter for the subject
garyq: Ganda ng fit nung FX-R sa OEM shroud ng Montero ah. Sakto! :thumbup:
sir gary, meron din ba fog retrofit for Altis 2007 model?
please pm how much. thanks.
Hi sir gary...what are the available packages nyo for starex 2002 model? Saan po sa the fort yung bago ninyong shop sa the fort? Im around the vicinity lang po and i would want to drop by sana...TIA!
sir garyq, im using global dmax..nkprojector na xa.what improvements pa pwd gwin sa headlights ko pati fogs.nkHID na projector ko but d ako mxado satisfied.and want ko din sna HID fogs ko..what can u suggest me to do with it? pa-pm nmn po..tnx!
[SIZE=4]Reminder: do not post messages in SMS/TXT shortcut format.
Read the rules.
Ignorance of the rules is not an excuse.
Repeated offenses will lead to banning.[/SIZE]
sir gary pa pm kung magkano abutin pag headlight at fogs pa retrofit ko, pati home service charge. nag kaka fogging headlights ko pag naulan or malamig pero nawawala naman. claim ko sana sa warranty pero mukhang normal naman.
kent: that is not normal especially with that amount of fogging pero we will solve it kung sealant lang problem. will send you a PM
javee: will send you a PM. Halogen projector lang kasi yan. Do be honest with you, mediocre talaga output niyan at best and placing hid bulbs will not really help as the width and intensity ng output dala talaga ng projector design (bowl and lens combo). Meron akong interesting suggestion sayo
