anyone knows where to buy those blinking brake lights?
yun ba yung triangle shape ala f1 brake lights? sa mga motorcycle shops marami
Yung F1-style LED brake lights parang sobrang gasgas na. Kanina lang ultimo trak ng basura meron.
for the sake of discussion, flashing blue lights on a vehicle means police trying to pull you over or trying to tell you make way
flashing white light means an ambulance on an emergency and sometimes with flashing red
flashing yellow means slow moving equipment and a road hazard.
check with local regulations and the department of motor vehicles first.
on cars with seven wire system, the brake light works as signal lights, so, if you make them blink, it will be hazard lights since the seven wire system does not have dedicated amber turn signal/hazard lights
Siguro kung third brake lights lang lalo na kung LED na yun stock. Mga 3-4 blinks before mag steady pwede na.. The purpose is to catch the attention of the cars at your back naman e, for me medyo added safety naman.
Sent from my LT26i using Tapatalk 2
The problem with blinking taillights – Editor Speaks | Autodeal
When it comes to blinking brake lights there are legal issues that surround it. The first is from the Land Transportation and Traffic Code, and the second comes from Presidential Decree Number 96. The Land Transportation and Traffic Code states that “every motor vehicle shall be equipped with at least one lamp which shall throw a sustained bright red light visible under all conditions, even under bright sunlight, when the brakes are applied.'' While Presidential Decree Number 96 has this to say: “That it shall be unlawful for the owner or possessor of any motor vehicle to use or attach to his vehicle any siren, bell, horn, whistle, or other similar gadgets that produce exceptionally loud or startling sounds, including dome lights, blinkers, and other similar signaling or flashing devices.” The strobing brake lights in question can technically be considered as blinkers since there is no distinction between those used by emergency vehicles and private vehicles as brake lights; it’s all up to interpretation. That’s two counts against these constantly blinking brake lights in the eyes of the law.
my beef against blinking brake lights,
is that when used with filamented bulbs, the bulbs may not get to shine as brightly as intended, thus bringing to question safety issues.
and yes,
there are the legal issues... "... sustained bright red light..."
Lto to punish driver with eye aching rear lights
"Driver with blinding tail lights suspended for 3 months - Auto News" https://www.autoindustriya.com/auto-...-3-months.html
