Results 11 to 20 of 32
- Jul 2003
- 579
- Jul 2003
- 21
August 25th, 2003 06:55 PM #13Mr. Doc Diesel,
Those residues were results of the performance of Biodiesel cleaning properties. Remember it has a high solvency factor, meaning it literally removes carbon deposits and unburned fuel inside your diesel engine. I would like to suggest to check your fuel filter. It is possible that there are solid residues also left there and affect the performance of your engine.
To everyone, don't be alarmed by these situation, you can verify it technically. It doesn't do any harm to your engine, else, it is already a path towards its full performance and efficiency.
Regarding the Flying V Biodiesel, I have read that in the Business section of the Philippine Daily Inquirer last wednesday. It is a good thing that there is competition, and it will be a point of consideration to other fuel companies. A step towards a clean environment.
The way I understood the article is that, similar to what we are doing with ESTROL Biodiesel right now, biodiesel will be blend to their owm diesel fuel. Just like what they done on 2001 and 2002 with the alco-gas. The question here is will they comply with the law regarding the 5% mixture of biodiesel. Or is their biodiesel accredited to comply with the 0.05% sulfur by volume.
August 25th, 2003 06:59 PM #14
hmm... punta kayo dito... aside from bio-diesel.. meron pang ibang alternative like WVO (Waste vegetable oil) and SVO.
http://biodiesel.infopop.cc/6/ubb.x?a=cfrm&s=447609751
01 EX Ody
- 437
August 25th, 2003 09:04 PM #15Originally posted by Ray
Mr. Doc Diesel,
Verifying it technically is good but seeing what really happens to the fuel and the filter is even better in the sense that it would support your tech. specs. If the residues go out by my 2nd full tank, then good. If not, what's this?
I'm in for a good product but out for an inferior one.
and here are the pix: www.photos.ph/asjamias dahan dahan lang at free account ito na may cap...
Doc Diesel
- Dec 2002
- 2,335
August 25th, 2003 11:16 PM #16Ray or Doc Diesel: Im planning to try the biodiesel on my Big Horn, 3.1 TDI, 4JG2 engine. Is this ok? ANo advantage? Tnx!
Tsikot Member Rank 3
- Dec 2002
- 636
August 26th, 2003 05:24 AM #17Doc D,
Great pics! What brand of fuel were you mixing with the biodiesel? Also, what was the fuel filter brand?
- Jul 2003
- 21
August 26th, 2003 03:00 PM #18That's great jack! Big Horn is great!!! Lalo na if you would use Estrol Biodiesel. You can start by using 5% blend of Biodisel to your current diesel fuel. Example: Full Tank = 40L X 5%= 2L of Estrol Biodiesel will be the blend. Thus, 38L of Mineral Diesel + 2L of Biodisel will compose your fuel tank.
How to physically blend? If your fuel is almost empty at least 1/4, pour the 5% Biodiesel to your tank before you fill it up again.
Expect that there will be an increase in engine power and 50% reduction on smoke emission. Also, after using it for quite a number of times check your fuel filters for residues, just like what Doc diesel had experienced. Don't be alramed because your Biodiesel is performing one of its positive properites which is acting as a solvent. It cleans the carbon deposits/unburned fuel in your engine and fuel line, this is one of its tricks why theres an increase in power.
Try to call us at these numbers for more info. :DLast edited by Ray; August 26th, 2003 at 03:04 PM.
01 EX Ody
- 437
August 26th, 2003 03:02 PM #19garyq,
try it. just don't use it on common rail injection systems. wala namang nakakasira sa pag-gamit ng biodiesel.
jackaroo,
Fuel is and was Shell Diesoline Ultra. Filter was replacement japan.
Doc Diesel
- Jul 2003
- 21
mag bid na ba ako :)
Tsikot.com is for sale!
