View Poll Results: BEST Unleaded Fuel: Shell, Petron or Caltex
Voters
126. You may not vote on this poll
  • Shell
    40 31.75%
  • Petron
    45 35.71%
  • Caltex
    11 8.73%
  • Total
    4 3.17%
  • Sea Oil
    13 10.32%
  • Uni Oil
    9 7.14%
  • Others
    4 3.17%
Page 47 of 49 FirstFirst ... 3743444546474849 LastLast
Results 461 to 470 of 488
    #461
    It got me a little bit worried after watching Shell's fuel video showing the gunk accumulated in the valve.
    I've been using Clean Fuel since the beginning of this year, coming from Total, mula nang magtuloy-tuloy ang pagtaas ang gas.
    And I'm thinking if the lack of quality additive can be offset by the use of Fuel Injector Cleaner or the bit more expensive Complete Fuel System Cleaner at least once a year or any fuel additives without breaking the bank.
    TIA
    i am of the belief that running the engine occasionaly in the highway at high speed, helps keep the engine clean. the so-called italian tune-up.
    but this is assuming, there is nothing wrong with the engine, except "carbon build-up".
    if there is something else that's wrong with the engine, no amount of complete fuel system cleaner, can fix it.
    my opinion.
    #462
    actually Sir ung nakita ko the gas station employee was pouring a bottle of something into the tanker truck
    Fuel nga yung laman ng bottle pang top up. Gaano kalaking bottle?
    #463
    How about the octane rating? Dinadaan din ba sa additives?
    Sent from my ASUS_T00J using Tapatalk
    No. Magkaibang fuel talaga yan. Ron 88 na pure gasoline yung regular 91 while ron 92 yung usual 95 octane. Then nilalagyan ng ethanol sa depot para umangat yung octane. Then lastly yung additives.
    TIA
    Sa Total din naman bumibili si Clean fuel so same lang.
    maliit lang.... Coke 500 or 237ml lang
    #465
    Ah yan yung bottle for testing ng delivery. Chinecheck lang nila kung may water before ibaba sa underground tank yung buong laman ng lorry.
    Nov 2014
    #466
    Gaano katagal ang aantayin for the result? Kung me tubig, void ba delivery?
    Meron ako piangpapa kargahan indie from TH daw 5 pesos cheaper sa mga station sa amin, kahit na nung mga panahon na sunod-sunod OPH eh parang hindi nababago o untoi lang tinaas nila. Kaya lang parang me mali everytime na nagpapa karga ako, kaya itinigil ko na.
    Balik ko lang yung Q ko na mas ok ba magpakarga sa mga newly opened na station(Big 3) dahil malinis pa yung underground tanker ?
    #467
    Quote Originally Posted by sp00nman View Post
    personally, i would avoid the new station, until the plumbing and tank had been cleaned of "imperfections" by multiple fills.
    by the same token, i try not to fill up at a gas station that had just received its tanker delivery, to give the "settlements" time to settle down. it's probably not an issue, but as i can afford not to...
    but that's just me.
    Nov 2014
    #468
    By 3s ba lahat ng interval, so yung Blaze ng Petron is RON 97 pure gaoline?
    #469
    Quote Originally Posted by Danils View Post
    regarding regular diesel, shell ang primary ko dahil advantage card. mas maganda ang andar at arangkada ng makina kesa nung nasa petron. ok din yung diesel ng caltex.
    regarding gasoline, hanggat kakayanin ng makina na hindi kakatok e regular ang ikakarga ko. mas dense ang energy content (thus more km/liter). mga makabagong gas engine lang naman maarte.
    btw, high RON do not equate to higher power, speed, etc. sabi sabi lang yan
    what gas engine are you, po?
    if the engine was designed for higher octane fuel, then it will function most efficiently using that higher octane fuel.
    the computer can detune it a bit, so's it can use lower octane fuel, but i believe its power output will also be decreased a bit.
    Dec 2014
    #470
    Itong 5 lang lagi nasusubukan ko.
    Petron - XCS swabe hatak, best FC for me
    Caltex - sakto lang hatak, ok din FC
    Phoenix - average hatak / average FC
    Seaoil - pinaka malakas hatak pero worst when it comes to FC
    Shell - Kahit 95 octane ko bakit parang ang hina ng hatak, ramdam ko yung ingay ng makina compared sa iba ang lakas din sa FC
