Results 1 to 10 of 18
- Apr 2019
- 81
- Sep 2006
- 2,746
June 5th, 2019 03:18 PM #2Have been using 91ron of shell and petron.
June 5th, 2019 03:22 PM #3
lately there have been reported cases of Honda BR-V units bought in the last 6 months that are having problem with their Fuel Pump. All of them use Shell.
mukhang nagpalit nang supplier ang Honda nang Fuel Pump nila.. if they are using the same Fuel Pump sa Civic.. I suggest wag ka muna magpa gas sa Shell..
June 5th, 2019 07:55 PM #4
Short answer: ANY FUEL IS OK.
I worked in the petroleum industry for a while and time and time again I'd see posts like this which means people actually think there's a difference between fuels. It's mostly just marketing, to be honest.
The reality is that base fuels are pretty much the same regardless of brand. Additives are different, but additives comprise less than 1% of the total fuel mix so net there's not much of a difference in day to day use.
If there's any difference, it lies more in how the dealers manage their stations. Most critical is to ensure no water intrusion in the tanks as this is what damages fuel pumps (not the fuel itself).
June 5th, 2019 11:37 PM #5
- May 2019
- 312
June 6th, 2019 04:32 AM #6Any Top tier brand. In my case, Costco gas is the cheapest top tier gas brand.
- Aug 2017
- 321
June 6th, 2019 08:58 AM #7
June 6th, 2019 09:06 AM #8
Honda's NA engines are rated for 91RON, even the Civic RS with a turbo engine is good with 91RON.
- Apr 2019
- 81
June 6th, 2019 11:11 PM #9Thanks. Ill go with unleaded rated 91. Try ko ung sa unioil na my discount. Ok lang ba mag mix? My half tank pa ako ng shell premium.
- Apr 2019
- 81
June 6th, 2019 11:18 PM #10Parang napansin ko din mga 3x nangyari pag apak ko gas ng madiin di agad kumagat ang pg accelerate compare sa ibang instances. Pde kaya dahil sa shell premium?
A 70/30 water to coolant mix may improve cooling efficiency but that's at the cost of less...
Coolant...
