Results 3,621 to 3,630 of 4200
- May 2010
- 186
February 14th, 2011 09:33 AM #3621Thanks Mile2. Now i understand that you had that tank cage sa welding shop. I thought (in your previous post) that GF did the customization for you.
On my case, i settled for their traditional bolt-in sa flooring and i also arranged for additional flatbar support since the tank is much bigger (65liters) para peace of mind. magvisit na lang ako sa welding shop after installtion para magpagawa ng much better support (if hindi ako 100% satisfied sa support).
quick question lang Mile2. i'm nearing my 20k pms. shell mineral oil lang po ba gamit niyo and stock spark plug? good naba don ang innova natin? I beleive you shifted back to mineral and stock spark plug (if i remember it correctly sa posting niyo).
salamat po ulit. this thread is very very helpful.
February 14th, 2011 09:52 AM #3622
I've been using regular mineral oil on my Altis (Petron Ultron Touring and Mobil 1000). Change every 5,000kms. No problem whatsoever after 55,000mks of using LPG on my engine.
As for spark plugs, if you see white residue on it when using your LPG, up it to a colder plug. I'm using NGK Gas (LPG specific plus) now and will probably try BKR7E's during my next plug change.
- May 2010
- 186
February 14th, 2011 01:10 PM #3623
February 14th, 2011 01:31 PM #3624
Feels the same but i would put my money on the Mobil 1000 as its specified to be suited for LPG engines.
- May 2010
- 186
February 14th, 2011 03:57 PM #3626
Yes I'm back using the stock long reach copper plugs Denso K20HR-U11 and Caltex Havoline mineral oil with sludge cleaning agent. Been with it since 2009 and so far I'm sticking with these.
The only colder plugs for Innova was Denso IKH22 which is Iridium and it cost too much, and just the same if you encounter dirty (oily) LPG it will also gets fouling.
BTW, about a couple of months ago, I replaced my head cover gaskets (no. 1 and no.2) and I could see that my cams and internal parts are still metal clean...I'm now a believer of no sludge additives of Havoline
I'm tempted to try Mobil 100 LPG whenever I'm at ACE Hardware, but could not find the right time when to buy and carry 6 liters oil
- Jul 2008
- 95
February 14th, 2011 04:48 PM #3627Has anyone experienced increased heat in the engine bay after LPG conversion? My apologies to all if this topic has been discussed already.
Cheers
February 14th, 2011 05:15 PM #3628
- Jul 2008
- 95
February 14th, 2011 05:37 PM #3629*ghosthunter thanks for the reply. Would you know the cause of the additional heat?
A friend told me it could be because LPG doesn't have any valve lube agent, unlike gasoline. So this leads to more friction between valves, seals, and seats resulting in more heat.
Just wanted to hear from users and knowledgable tsikoteers.
Thanks again:-)
- May 2010
- 186
February 14th, 2011 06:19 PM #3630
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
