Page 353 of 420 FirstFirst ... 253303343349350351352353354355356357363403 ... LastLast
Results 3,521 to 3,530 of 4200
    #3521
    Quote Originally Posted by zed2d View Post
    Bro I'm using their vogas plus dual sequential system. The kit has be installed last month. and right now we're just having problem with the fuel consumption mga 6-7:1km/L .
    what is your car and what was your FC before?
    Mar 2007
    #3522
    Zed2d,
    I hope I'm not intimidating you with my questions.
    Did Econogas made any settings on your car for petrol/lpg ratio, or did you simply go for 100% LPG?
    Is this the car you plugged the kit with?
    http://www.marutiwagonr.com/
    Hope your f/c issues are resolved. I'm eying to fit that kit on my APV, soon.
    #3523
    bro straker the setting that I'm having right now is pure lpg up to 6000rpm and anything onwards to redline 8000rpm the petrol injectors takes over.
    #3524
    Mga Bro's just an update to my lpg installation after a whole day of fine tuning my wagonR at econogas we finally manage to get the mixture and settings right. Happily My FC is now 1L:15.3km on lpg.
    May 2005
    #3525
    Hello Guys, Im about to get a 2004 Expedition equipped with Tartarini LPG kit.
    According to the owner no worries but I want to hear it from you if there are any no problems with it. I'm new to LPG equipped SUV and I'm a bit worried about some horror stories that I have heard. Some are, Spark Plug get busted quickly, valve burn injectors clogging and rubber sealant, etc.
    Are these true? I have talk to some friends that are using it already for more than a year now and according to them they don't have any problem with it.
    Is there anybody here using Tartarini with the V8 engine? TIA
    May 2005
    #3526
    How many KM using LPG? How much did it cost you for Injector cleaning? Is the dirt from LPG alone? Thanks!
    Quote Originally Posted by n5110 View Post
    had my car injectors serviced at servitek laspinas
    >> ganito kadumi yung mga injectors.
    "> one of the injector spray pattern not as good as the 3.
    "> >> my injectors taking an ultrasonic bath ( mga 15-20mins)
    >> after cleaning the injectors, spray test ulit now you can see even spray on all injectors.
    >> after this gumamit ng engine analyser similar sa mga emission testing center to adjust to right a/f mix.
    >> satisfied customer. nawala ang idling at jerking problem ng kotse ko...dati iniisip ko na sa suking talyer ko lang dalhin, buti na lang at sa servitek ko dinala. at least now i can say na 95% adjusted yung kotse sa tamang setting at hinde sa tatsa-meter.
    #3527
    good day to everyone! Ang haba na ng thread hahaha. For those who still have doubt about using lpg conversions, i had my suzuki samurai converted 7 yrs ago here in davao when we are only two lpg vehicles running on it. My children used this car to and from school during their college days, Now they are professionals and they still love using this car tho we have acquired two more late vehicles, No problem for 7 yrs, oh theres one when the timing belt gave up and had to take out the cyl head for inspection. When inspected its like brand spanking new! Never changed the spark plug for 7 yrs, bosch platinum had to clean it once a year tho not dirty yet but to see if its still removable baka na welding na sa cyl head hehe.
    No change in hp from 9km/l gas to 8km/l lpg not never regreted shifting to lpg. Hope this helps in anyway
    #3528
    May 2005
    #3529
    * jojo hernandez, Wow! 7 years. Pero question ko is gaano kahaba na ba tinakbo ng Samurai with LPG in terms of KM? Kung Expedition V8 will you still use LPG?
    Sulit parin ba talaga? Kahit masbilis mapundi yun plugs at Mabilis dumumi yun Injector's and some also claims na pati daw valve affected din.
    Main reason kaya interesado ako is nakikita ko na fuel prices are going up until December this year. Sayang din kung makakatipid ako pero kung mas magastos ang maintenance parang talo din. Just a thought. Thanks!
    #3530
    * larshell my sammy has gone more than 160k with 2 timing belt belts replacements, still runs like a dream, thats on lpg since i condemned my fuel pump and gasoline tank about 5 yrs ago.
    There are expi's and trailblazers here in davao on 100% lpg and i haven't heard any complains from owners. I'm also into converting my two efi vehicles, however im still looking for a reliable sgi installer here. All i can say is that for carbed engines go lpg hindi masyado maselan sa oily lpg just spray the carb an air intake with a good carb cleaner and forget it. It will keep on running just do regular oil change every 4 to 6 mos or so with motor oil suitable for lpg fueled engines and you'll be ok.
Auto-LPG Conversion Thread
