Results 2,651 to 2,660 of 4200
September 8th, 2008 11:58 PM #2651
September 9th, 2008 08:09 AM #2652
it may have been the incline, and fuel tank tilted and fuel went away from the the hoses leading the the engine? It's definitely not an LPG problem. Tama si GH, your battery may be starting to show signs of old age. Have your alternator diagnosed na rin (free naman diagnosis sa battery shops eh).
- Jul 2008
- 13
September 9th, 2008 12:22 PM #2653Hi tsikoteers, some more questions:
1. is it correct to say that a well-tuned venturi/emulator conversion will be able to maintain the FC and power of the car at low rpms (up to 4k)?
2. is it correct to say that the FC and power loss inevitable with a venturi/emulator conversion will be found only at higher rpms (5k and above?) ?
3. is it correct to say that the advantage of a closed loop system versus the open loop system is that the settings for tuning it will be provided by the ECU, but on-the-fly performance will be the same as a well-tuned open loop system?
Thanks in advance for the replies.
September 9th, 2008 02:19 PM #2654
No. Venturi systems can get close but not equal the FC of gasoline. Expect a loss of fuel mileage of 5% to 10% depending on tuning. Running lean, it is possible to match or exceed the gasoline FC figures but performance suffers as possibility of engine damage in the long term.
- Aug 2008
- 24
September 9th, 2008 04:33 PM #2655Thanks Xoom and GH.
Sana nga may 60L toroidal sila but I'm guessing walang available.
So if its a 40L tank, the useable amount would roughly be just 30L.
My FC on gasoline is 10.5km/L (last fill up ko).
So on LPG on my Mazda 3 lets say 8km/L lang siya.
My range would be 240km per fill up. Hmm that'll last maybe 3 to 4 days tops.
Called them up and I told lorna kung pwede sa kin nalang yung 55L toroidal na dadating=) pumayag naman. (increases my range to 330km)
I hope the conversion of my car goes well.
Here's an experience I had driving the Camry my dad converted to LPG yesterday. (Coding kasi car ko) On my way to the office at around 930am all was fine and it could even reach 100kph like gasoline.
Upon entering the parking ramp and getting the ticket from stop. The car had a hard time rev'ing up but I was able to park. So I thought... that was weird.
Ok on my way home at around 730pm it was raining really hard. So I thought hey this is good, LPG supposedly runs better in colder conditions.
So from Pioneer upto Buendia, all was fine then there was heavy traffic approaching the underpass of edsa cor ayala. It was crawling. So ok lang. Then after a few mins from STOP the car was losing power again, having a hard time rev'ing up. A few meters forward STOP ulit then Go ulit, the car was having a hard time rev'ing up when its on Drive and Stopped for a while. On my 4th attempt, it was really having a hard time to Rev up..... the car stalled. Turned off everything after less than 5 secs I started the car on Gas.. Vroom... No problem...
Approaching the incline of Magallanes the car automatically switched to LPG...toink! I was able to climb Magallanes but I definitely do not have the power, so parang Diesel siya umakyat...hehe bagal.
Traffic was moving fast again and the LPG was fine again from Nichols all the way to Alabang. WEIRD.
I told my dad the camry still needs to be fined tuned it looks like it has problems when STOPPED and on Drive for a long time.
Here's my question regarding SGI kits...
For example on my Mazda 3 it has a O2 sensor. Does the A/F mixture "Adapt" / Change in real time based on how my engine is doing?
Does the ECU do this thing?
I'm thinking sana my Mazda 3 conversion has less problems kasi its a newer model that's more compatible with the SGI kit.
In the case of my dad's camry the A/F mixture is like Pre Defined so it doesn't know to change the A/F mixture when needed?
Does it act like a SGI kit? or like a Open Loop lang? (na Fuel Injected)
September 9th, 2008 07:08 PM #2656
On stock tuning, the LPG injectors will mirror exactly what the gasoline injectors are supposed to do, with a slight correction factor put in so that your stock O2 sensors will be happy... but it's your stock ECU that controls closed-loop tuning and the preset ECU maps that control fuel... the SGI computer just translates those instructions for the LPG injectors.
Thus, it's really important that your LPG AFRs (air-fuel ratio) closely mirror your gasoline AFRs in closed-loop (typically 0-3000 rpm on a modern engine) so as not to cause weird running due to your stock ECU trying to adapt to the LPG.
But the cold running issues can be due to tuning and/or vaporizer/coil mismatch issues. We're still discussion ways to figure out how to regulate fuel pressure when it's cold... apparently, changing the fuel pressure setting on the LPG vaporizer helps for some people... we're looking at the problem.
September 9th, 2008 07:17 PM #2657
Sounds like the Camry needs more time to be tuned well.
As for the Mazda3... the M3's ECU is uber sensitive. Even our Mazda3 1.6L still experiences occasional CEL (check engine light) at around once every month to once every two months. Other than that, the car runs pretty well although it experience initial problems like power loss and stalling until the LPG kit was tuned by SPEEDLAB.
- Jul 2008
- 13
September 9th, 2008 08:14 PM #2659
Power loss starting mid range RPM (or around 3500 and 4500). This is because you are trying to suck in more air through a small openning. At low RPM, the openning is adequate but at higher RPM, it becomes a constriction.
FC in well maintained system, keeping the engine running at lower RPMs can help maximize fuel mileage (as with any fuel).
Just imagine the difference in a carb and fuel injected engine. The analogy between venturi and SGI systems are pretty much alike. The efi systems are more efficient. Carb are easier to tune in DIY situations but are sensitive to any changes like airfilter condition and atmospheric pressure changes.Last edited by ghosthunter; September 9th, 2008 at 08:19 PM.
September 9th, 2008 08:45 PM #2660
yep, i always use my petron bpi credit card whenever i fill up with petron's xtend. and i get rebates on the proceeding month
Hyundai Santa Fe GLS 2024
Tsikot Hyundai Registry
